turbo s2000 tuning
Old Apr 8, 2010 | 06:53 PM
badassf4i's Avatar
Default turbo s2000 tuning
well i have just finished installing the greddy turbo kit on my ap1 s2000. it is using the greddy e-manage ultimate to controll everything. it comes loaded with a base map but it is not making any power at all. i am in despirate need of someone that has experiance with tuning this system. i have tried searching all over the web for a tuner but have had no luck. im not wanting to make the car a beast i just want it to have at least 270ish to the wheels with a good a/f. any help would b greatly apreciated because i realy am ready to drive this thing.
Old Apr 8, 2010 | 07:48 PM
YARO's Avatar
Smith & Wesson Protected.
Call Alpha 727 505 1423. http://inductionperformance.com/ He will tune your car and advise at what you need. IMO get rid of that greddy Stuff and go AEM ems or other.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Apr 9, 2010 | 01:49 PM
NeKe1point0's Avatar
Good advice !
Proven Power LLC
4505 N. 56th street
Tampa, FL 33610
813-988-DYNO(3966)
www.ProvenPowerTampa.com
Old Apr 9, 2010 | 02:15 PM
b15spec's Avatar
aint no reg. spec-v
you should be making more than 270 even on a bone stock motor!
https://www.tamparacing.com/forums/signaturepics/sigpic51275_1.gif
Old Apr 9, 2010 | 09:55 PM
mtber's Avatar
Check here: https://www.tamparacing.com/forums/h...directory.html
I would ditch the greddy piggyback & use aem ems as mentioned above.
The greddy kit maybe a limiting factor for your setup.
If done right a setup can flow really well, example: I recently tuned an s2000 with a completely stock motor with a kit the customer put together him self. It made 380 whp at 10.5 psi on a dynojet.
Good luck.
Old Apr 10, 2010 | 06:12 AM
The Spectacle's Avatar
Spent more money than you
You're in luck...Mase is coming into to town next week. I highly recommend you sign up: https://www.tamparacing.com/forums/p...th-2010-a.html
Racing Integration
LHT Performance
My tuner is named Alpha
