windows some times dont go down or up please help!
Old Apr 8, 2010 | 03:22 PM
livelife787's Avatar
lowndslo
Default windows some times dont go down or up please help!
i have a 94 acura integra rs. My problem is that some times my windows dont go down or up after a while it starts to work again then it would stop working i swicthed out the relay for the swicthes to see if that worked but its still doing the same thing if some one can help me out i would really appriciate it thanks TR
Old Apr 10, 2010 | 05:33 AM
flatrex's Avatar
crx hatch sedan
Possibly the switch is pooping out.
Old Apr 10, 2010 | 06:59 AM
BoostedRacerDad's Avatar
Pops
Start out opening the underhood fuse relay box and make sure Fuse 36 is a 50amp. It is higher amperage rating as the circuit is protected with 20 amp fuses from the underdash fuse box and lets you open windows up or down at the same time. Go to undash fuse box and make sure Fuse 8 and 5 are 20 amp. These are for passenger side and driver side. Fuses 4 5 7 8 are all 20 amp and are for Four door models.
Move onto the switches.
1.Does passenger side operate fine from passenger side switch?
if no remove switch and with a 12 gauge jumper jump blu/blk to blu/red for down then blu/blk to blu/grn for up. If window goes up and fine with jumper then window regulator and motor are good. Hook switch back up.
2. Move over to Drivers side remove switch
jump wht/yel to red/yel for up wht/yel to red/blu for down
do window move smoothly up and down? Then window regulator and motor are good.
Hook everything back up and isolate the problem to either the drivers side switch or passenger switch( if any problem with passenger side)
If the window regulators and motor operates fine with the jumper I would look at replacing the drivers side power window switch.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Apr 14, 2010 | 12:42 AM
+1! Excellent advice.-Bob
