Going Turbo......????????
Old Apr 5, 2010 | 08:32 PM
EK91Project's Avatar
Default Going Turbo......????????
planing to go boosted.................
i have b18c1 with high compression piston 11.8.1 (wisco) .
i wana get thicker head gasket but i dnt know how thick i should get it and how low i should drop the compression. any pointer?
My EGg Hatched ..... Honda Rock!
Old Apr 5, 2010 | 09:30 PM
mtber's Avatar
Depending on your ultimate power goals & fuel type I would suggest dropping the static c/r to around 9.5:1-10.0:1
I have used thicker cometic MLS gaskets on JDM itr motors with good results.
I also know inlinepro distributes their own brand of bseries headgaskets also.
Old Apr 5, 2010 | 10:17 PM
FrodoGT's Avatar
Found the Vtec switch.
Im not sure you can get the CR below 10:1 with just a head gasket.. at least not one likely to hold well.
I think the best youll get will be in the mid 10's
TR Old Skool EF Crew #24
