ring and bearing help
Old Apr 2, 2010 | 06:05 PM
mr.hatch's Avatar
EKallday
Default ring and bearing help
I'm in dire need to do the rings in my car so I'm just asking for some advice.
I have a boosted GSR with B16a head GSR bottom end with wiesco pistons on scat rods with a stock crank, my question is what rings and bearings should i go with for this setup and what should i gap the rings to.
I would very much appreciate all the info ASAP b/c i want to get the parts tomorrow morning so i can have it done by the time i have to go to work Tuesday.
Thanks Nick
Old Apr 2, 2010 | 07:04 PM
rangcrx's Avatar
engine building &best
rings i would go with ordering some from wiseco,and bearings go with acl..as for gap others im sure can answer that
i love AUTOZONE
Old Apr 2, 2010 | 07:35 PM
YARO's Avatar
Smith & Wesson Protected.
I would do Honda or ACL bearings. Wiseco rings. top ring gapped .020 bottom ring .024. You can ask wiseco for gaps when you order your rings. Can you post more info on the setup is it sleeved and what power? Make sure to check w2p clearance when all that comes aprt. Also check clearances on the bearing with plastigauge.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Apr 2, 2010 | 08:29 PM
mr.hatch's Avatar
EKallday
i have a ported and polished B16a1 head with gsr cams with gsr springs and titanium retainers, stock bore and sleeve, i don't know the power because i put a 250 walbro fuel pump from the last dyno test and a different turbo which is almost like a gt40r but i may be wrong so don't criticize. If you need anymore just let me know
Old Apr 2, 2010 | 10:57 PM
mr.hatch's Avatar
EKallday
anybody have some thoughts to give out
Old Apr 3, 2010 | 09:23 PM
JDMJNKY's Avatar
NiteGrindTransmissions
we'd need a lil more info. How many lbs of boost are you now running? and with out knowing turbo size, your practically shooting in the dark.
Phil. 2:3-5 |
  • 1213 AFFILIATION - JDMKIDS | CALI | AS1 FAMILIA
Old Apr 13, 2010 | 09:51 AM
mr.hatch's Avatar
EKallday
i am only running abput 8lbs. and the info is above
Old Apr 13, 2010 | 12:54 PM
JoKiE crx4294's Avatar
popeye built!
Corey still around?
Can't spell strength without tren
AAS...It's whats for dinner
