need a little helpp ls swap in crx obd2 to 0bd0
Old Mar 13, 2010 | 07:46 AM
o4jdmrolla's Avatar
Default need a little helpp ls swap in crx obd2 to 0bd0
hey im wondering i got a 98 ls an im putting it in a 91 crx im wondering is there anything i have to change on the motor for my si obd0 wire harness to plug up to lmk asap thanks
special K
K*Squad
‎135
246 R
Old Mar 13, 2010 | 11:30 AM
custom240sx's Avatar
DC Crew Member #1
obd0 pr4 ecu, obd0 distributor (b-series), obd0 injectors or cut and remove resistor box (if using obd1/2 injectors), 1 wire o2 sensor, and that should be about it.
Old Mar 13, 2010 | 12:24 PM
o4jdmrolla's Avatar
thanks bro so after that every thing should be plug an play rightt
special K
K*Squad
‎135
246 R
Old Mar 13, 2010 | 01:59 PM
DC Crew Member #1
You may have some sensors on the block left over after plugging in the harness just to let you know.
Old Mar 15, 2010 | 06:30 AM
o4jdmrolla's Avatar
o yea thanks but the sensor i just leave them right an my car should still run normall rightt
special K
K*Squad
‎135
246 R
Old Mar 15, 2010 | 02:32 PM
DC Crew Member #1
So long as all the wiring harness sensors are in place then yes it will run fine. If there are any left over it would be a knock sensor and crank timing sensor(the one be the crank pulley I don't remember the exact name)
Old Mar 15, 2010 | 05:39 PM
o4jdmrolla's Avatar
alright man thanks 1 more? the altinator has to be changed to right
special K
K*Squad
‎135
246 R
Old Mar 16, 2010 | 06:26 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
no, alternator is fine.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Mar 16, 2010 | 10:28 AM
DC Crew Member #1
Actually the alternator will need a tad bit of work to get it to plug into the stock harness...it's very easy though so don't worry.
Take off the metal cover that goes over the plug area on the alternator...now trim it a bit so the crx plug will slide through and then reinstall...very easy.
Old Mar 19, 2010 | 06:06 AM
o4jdmrolla's Avatar
wrd thanks alot bro
special K
K*Squad
‎135
246 R
