92-95 eg/94-01 dc2 trailing arm bushings
Old Mar 1, 2010 | 04:15 PM
GZndEG's Avatar
Default 92-95 eg/94-01 dc2 trailing arm bushings
We all know about the pain-in-the-@$$ trailing arm bushings correct? Not only is it cheaper to buy a [Hyperfflex] bushing kit, but it's less of a strain to swap...or is it? The instructions make it seem pretty easy, and it is, to install the new bushing with two 4" washers and a well-sized bolt. The problem is i can't find a damn washer tht fat, not even in the industrial "Fastenal" hardare store, without paying $50+...
-So my question is does anyone have advice on gettin the bushings in without paying more than I did for the bushing kit itsef?
Old Mar 1, 2010 | 05:57 PM
89crxsir's Avatar
Where i work has a bearing kit that has all different sizes "press" pieces. How big is the opening of he bushing?
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Mar 2, 2010 | 12:42 PM
GZndEG's Avatar
it's just under 4" but i would imagine a least a 4" cut would be needed so the bushing doesn't "cave in." problem is I don't have a press, otherwise there would be no questions hehe
Old Mar 2, 2010 | 01:21 PM
89crxsir's Avatar
They are not used in a press. They are press pieces http://www.baumtools.com/pdf/B90Kbwnew6.pdf The biggest piece I have is 4.36" if you have a bolt and nut that will fit..
Old Mar 2, 2010 | 04:32 PM
GZndEG's Avatar
I'd appreciate it, but one question, "do you have two?" Hehe, wouldn't do me much good with one 4"+ and nothing on the other side.
Old Mar 2, 2010 | 04:46 PM
89crxsir's Avatar
I might have 2, i'll look tomorrow at work
Old Mar 3, 2010 | 09:29 AM
GZndEG's Avatar
send me a text 813-403-2783 and let me know. thanks in advance, and where you located anyhow?
