Originally Posted by Delsolb16r
(Post 7561874)
.I also have a lot of air pressure building up beneath the valve cover which I think might be causing the oil leak.
Advice? PM me or just post here. |
You aren't supposed to use silicone. If installed correctly, just the gasket is needed. I have never and will never use the silicone. It causes a mess. Honda/acura never used silicone when installing these gaskets from the factory.
Well if you use the silicone right it wont cause a mess...i use it to make sure i wont have any leaks and it stays there.
Originally Posted by custom240sx
(Post 7658557)
You aren't supposed to use silicone. If installed correctly, just the gasket is needed. Honda/acura never used silicone when installing these gaskets from the factory.
