cluch n tranny questions.
Old Feb 23, 2010 | 09:40 PM
PSYCHOBUILT's Avatar
Dude you dont even knooow
Default cluch n tranny questions.
I dealt with mostly single cams. now im in b series looking to change out my tranny and clutch. i know with the single cams u cant use a clutch from a dx or lx setup ,on a si tranny. will a clutch from an LS cable tranny setup work on a b16 cable tranny? or the splines different? Or as long as the clutch is for a cable tranny period? Also what would be the correct clutch cable to use for a b series into EF swap? any info would be appreciated. thx TR
You laugh at me cause im different. i laugh at you cause your all the same.
Old Feb 24, 2010 | 01:56 AM
custom240sx's Avatar
DC Crew Member #1
Clutch cable = stock EF one...DA will not fit the right way
as for clutch...depends on year of transmission...90-91 has a smaller spline and 91-92. The clutch is the same but the pressure plate and bearing aren't.
Old Feb 24, 2010 | 09:59 AM
^thx for info
Old Feb 24, 2010 | 10:05 AM
r u sure about the stock ef clutch cable? theres no slack what so ever in the line,n thats with adjuster nut adjusted all the way up. thats not good. feels like the clutch is being riden on. what are free play tolerances?
Old Feb 26, 2010 | 10:06 AM
DC Crew Member #1
Yes I am positive about the stock EF cable...I have done many of these swaps.
Old Feb 26, 2010 | 01:53 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
^+1 for what custom said.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
