Help!!!!!!!!!!!!!!!!!!!!!
Old Feb 17, 2010 | 12:32 PM
PITORACING's Avatar
TITAN
Default Help!!!!!!!!!!!!!!!!!!!!!
i have a dohc zc motor. my problem is that the dizzy that was on had 7 plugs on the connector. the new one i bought only has 5. what do i do to make this work.its a tdo3u help.the old dizzy connector was touched to my times wire stripped and un plugged.
Old Feb 17, 2010 | 03:23 PM
88_Hatchy's Avatar
I'm cooler than you
I can't figure out why people that have been on her for years can't seem to post in the right forum.
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Feb 17, 2010 | 03:29 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
eh... this is right?
is the connector square or circular? if it's square it's obd1, circular it's obd0. you'll need the correct dizzy (ie: obd1 chassis = obd1 dizzy) unless you want to start cutting wires.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Feb 17, 2010 | 04:38 PM
PITORACING's Avatar
TITAN
the new one is square.
Old Feb 17, 2010 | 04:47 PM
wakeking48's Avatar
Yes!!!!
I believe you have the wrong dizzy
Old Feb 17, 2010 | 05:37 PM
PITORACING's Avatar
TITAN
ok i got the car to start but now only three spark plugs get spark.what can that be
Old Feb 17, 2010 | 05:39 PM
wakeking48's Avatar
Yes!!!!
Like i said on other post check your wire, if it is not that it has to be your cap
Old Feb 19, 2010 | 08:17 AM
CRAWFORD BUILT
^+1 the rotor may not be making contact with the cap on one cylinder.
CRAWFORD BUILT
DC Crew Member #23
