gsr head on LS block, whats the comp ratio?
Old Feb 14, 2010 | 06:04 AM
sullivanracing06's Avatar
Default gsr head on LS block, whats the comp ratio?
hey, i just built a ls/vtec motor for a friend of mine and im wondering what the compression ratio would be? factory short block with a 94 gsr head?
thanks, tom
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Feb 14, 2010 | 08:24 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
9.6:1 - P74 LS Pistons
10.0:1 - P72 GSR Pistons
and this is if the head isn't milled.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Feb 14, 2010 | 08:36 AM
88_Hatchy's Avatar
I'm cooler than you
~10.2:1, but you won't be able to rev it very high on stock LS rods (rod bolts).
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Feb 15, 2010 | 10:45 AM
8.5-1 wesico pistons, eagle rods, arp rod bolts and arp main studs, type r oil pump and type r water pump. acl race main n rod bearings, non milled head
Sullivan Racing LLC
352-665-2496-Tom
Old Feb 15, 2010 | 05:06 PM
zhillz's Avatar
Porno Music Producer
Compression Calculator - Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedracing.com
Old Feb 15, 2010 | 07:35 PM
CRAWFORD BUILT
...when using the calculator you get 9.55 which is what i said the first time.
CRAWFORD BUILT
DC Crew Member #23
Old Feb 15, 2010 | 09:25 PM
well thanks for the help
between turbo edit, the new 800s, wideband and egt i should be fine
Sullivan Racing LLC
352-665-2496-Tom
