Need Mech or shop for rear bushings?
Old Feb 10, 2010 | 09:08 AM
elmcityrican's Avatar
Default Need Mech or shop for rear bushings?
I need the rubber bushings replaced on the rear-axle, and supposedly can only be done with a pressure- machine @ a shop?... never replaced that before so Im not sure. I have the bushings for both sides L/R.. any suggestions or people out here? Im in the Town n Country area in Tampa..LMK text 727-369-8920 or PM me.
Old Feb 10, 2010 | 05:26 PM
thegoldenchild's Avatar
thats so easy, 15 min per side.thats so easy, about 15 min per side. No need to disconnect brake parts such as calipers, rotors,brake shoes, brake fluid lines and emergency brake cables.
step 1 rent this from advance or autozone
step 2: do it yourself
step 3: thank me for saving you a fortune.
Old Feb 11, 2010 | 02:44 AM
rangcrx's Avatar
engine building &best
^i think his talking about the control arm
i love AUTOZONE
Old Feb 11, 2010 | 03:59 AM
buy aftermarket then
Old Feb 12, 2010 | 05:12 AM
1nycelude's Avatar
***boosted***
do not use that tool^^^!!!!!!! it has proven to damage the rear trailing arms. the rear trailing arms are taper to be small towards the inside of the vehicle. if you press the bushing threw to that side it will distort the rear trailing arm. the bushing needs to be taken out towards the outside of the vehicle.
i once felt bad cause i had no turbo!! then i met a man that had no VTEC.
Old Feb 12, 2010 | 05:58 PM
ive done many and never had any problems or complaints.
Old Feb 13, 2010 | 05:36 AM
1nycelude's Avatar
***boosted***
go look at the honda, or acura service manual. the bushing are to be pressed from the inside of the trailing arm out.
