Iam not sure if iam the only one that has this problembut my clutch pedal has been doing this forever and it anyoing to me. I feel like my car is trasy when i hear it. After awhile it stops squeking. Does anyone have a solution. Somone told me that its the realese bearing or the pedal. Iam not sure can someone just pin point the problem. It squeaks bad for awhile then after it runs on the road for awhile it fine. Also another pro. is that when iam in 1st gear it really makes a werid noise like it catches then i hear a really noisy sound like a spinning sound i think someone would be better hearing then explaing its hard to tell .
The squeak is usually the result of a lack of lubrication on the pivot ball that the release fork sits on. You can usually wiggle a oil can into the space and lubricate it but Id suggest caution because you dont want to oil over and onto the clutch plate.
As for the other noise Ive got no idea. Sounds like a tranny problem...which isnt good. |
what required to fix the squeaky noise.
need a grease gun thats all
How do i get to the pivot ball so that i can grease it down. Does the need to be done by a person who know how to disamsble and reasemble the tranny.
