95 prelude si problem
Old Jan 16, 2010 | 06:38 AM
acuralsb18's Avatar
Exclamation 95 prelude si problem
95 prelude si wont start has fuel spark and air what could be the problem ive tried just about every thing possible
TR "Old Skool DA" Member #17
Old Jan 16, 2010 | 05:24 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
you need 4 things for a motor to run
-fuel
-spark
-compression
-timing
one of those systems aren't working.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Jan 16, 2010 | 06:33 PM
zhillz's Avatar
Porno Music Producer
^ speaks the truth
What exactly is it doing?
Old Jan 17, 2010 | 05:20 AM
acuralsb18's Avatar
starts up for a sec then shuts off if oil got in the dizzy could it have messed with the pick up inside of it
Old Jan 17, 2010 | 07:04 AM
CRAWFORD BUILT
if you have spark then it's not your dizzy, but check and make sure you have spark on every cylinder. check fuel pressure, you should be at 43psi. and do a compression check, it sounds like fuel pressure or compression.
CRAWFORD BUILT
DC Crew Member #23
Old Jan 17, 2010 | 07:49 AM
acuralsb18's Avatar
its got both im wondering if its the crank position sensor cuz on these motors its in the dizzy
Old Jan 17, 2010 | 10:06 AM
acuralsb18's Avatar
iv put new injectors spark plugs wires dizzy cap and rotor and its not throwing any codes can some one help please
Old Jan 17, 2010 | 03:41 PM
CRAWFORD BUILT
check compression
CRAWFORD BUILT
DC Crew Member #23
