d16a6 into 91 ef
Old Jan 15, 2010 | 04:09 PM
91_4door's Avatar
4 doors of fury
Default d16a6 into 91 ef
hey guys I have a 91 ef, dualpoint stock motor, I wanna put a d16a6 in, im unsure or what ecu to use, also can i reuse my old motor mounts? Will I need a resistor box? Is there someone that sells a complete harness plug and play? and would i benifit from swapping the d16 in as far as performance gains and last question is there anyone on here that has a full swap they are trying to sell.
Old Jan 15, 2010 | 06:13 PM
FrodoGT's Avatar
Found the Vtec switch.
Originally Posted by 91_4door
hey guys I have a 91 ef, dualpoint stock motor, I wanna put a d16a6 in, im unsure or what ecu to use, also can i reuse my old motor mounts? Yes
Will I need a resistor box? Yes
Is there someone that sells a complete harness plug and play? Yes, rywire.
and would i benifit from swapping the d16 in as far as performance gains The A6 has more power, but youd benefit alot more from a vtec head plus the a6 block
Here.
TR Old Skool EF Crew #24
Old Jan 16, 2010 | 07:56 AM
91_4door's Avatar
4 doors of fury
thanks
Old Jan 16, 2010 | 11:20 AM
custom240sx's Avatar
DC Crew Member #1
That swap with a vtec head and a short geared tranny has good potential. I'd say it would put you right in the same power range if not a bit more than a b18a1 swap (with bolt ons).
Old Jan 16, 2010 | 03:25 PM
chi town brat's Avatar
! Ne shab'rud'ni !
you can also pay someone to wire up your system as it may cost you less money. i did this to my dual point when i put in my d16y8 engine.
Old Jan 16, 2010 | 07:38 PM
Thatguysstuff's Avatar
Hey its that guy!!
Allot easier to use a obd1 intake manifold with obd1 sensors and injectors.. No resistor box needed..
if you want to know how... Pm me.. I did it to my rex...
went from this..
to this...
