tailights wire problem
Old Nov 24, 2009 | 06:28 AM
evo911's Avatar
Default tailights wire problem
MY tail lights went out but i kno my bolbs work. they keep goin out and on and i think its the wiring cable is loose or somethin. i got a 1996 civic ex idk where the wires are at? someone told me there behind the radio where all those wires are but im not sure i need help finding them someone help plz thanks
Old Nov 24, 2009 | 06:41 AM
hondaking625's Avatar
DB1 FTW!!
well first of all the wiring for your tail lights should be in your trunk so start there and check all the cables for a loose wires or something that may be shorting out the lights, also check under your dash on the drivers side and you will see your fuse box check to see if your fuse is blown and then replace it .PMM ME if u have any further questions
Old Nov 24, 2009 | 09:06 AM
freakasis's Avatar
any eveidence of water in the light housing?
"Black people can't be racist" - Some black guy.
Old Nov 24, 2009 | 10:04 AM
evo911's Avatar
i checked the fuzes they work. i turn the switch to turn on my lights and the break ones came on. but.. when i press the brakes they dnt bright up they dnt work. but they turn on when i flip the switch.. i need help
Old Nov 24, 2009 | 10:12 AM
evo911's Avatar
no. but if thats it then all it needs is to be dried
Old Nov 24, 2009 | 06:32 PM
freakasis's Avatar
so the tail lights come on but not the nrake lights? that sounds like the brake light switch has gone bad.
Old Nov 25, 2009 | 11:20 AM
thegoldenchild's Avatar
ok first of all they are called running lights, those turn on when you turn on the switch.
