gas tank issues-help please
Old Nov 20, 2009 | 06:28 PM
lopezchris21's Avatar
Default gas tank issues-help please
well i just picked up a hatch and the fuel pump was bad and when i pulled it out it was all rusted. Car was sitting for about 3 months, so i was told. The gas smells like crap tho and doesnt smeel good. has about quarter tank in it. I put 6 gallons of 93 in there along with octane booster and fuel injector cleaner. I changed the fuel filter cuz the old one when i flipped it had brown crap coming out. well i took off the gas line to the fuwl rail and turned the key. car squirted gas out fluent and nice and ther was nothingi nthe gas. Should i be worried about the tank at all or just ride it out and see wat happens?
anything wil help.
thank you
chris
TR 5th Gen Civic CREW Member # 04
Old Nov 20, 2009 | 06:32 PM
YARO's Avatar
Smith & Wesson Protected.
Yes the tank needs to be replaced. Don't risk it unless is just a beater you don't care about.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Nov 20, 2009 | 07:38 PM
Nandosol's Avatar
Garage Slut
Fuel does go stale. Have you tried cleaning the tank? Is it salvageable at all? If you have rust holes in your tank that sucks.
Old Nov 20, 2009 | 08:05 PM
rangcrx's Avatar
engine building &best
that rust is normal just use a magnet and clean it out..3months is not that long but if you hav any doubts you can drain the tank easy there is a bolt on it to drain like a oil pan..
https://www.tamparacing.com/forums/h...-look-why.html
i love AUTOZONE
Old Nov 22, 2009 | 07:51 AM
lzylst's Avatar
If you need a hatchback tank i have one that is clean.
Vance @ 863-604-2139 for any questions
Old Nov 22, 2009 | 08:05 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
i had an integra sit for 6 months with half a tank of gas and it fired up after a motor swap. i didn't put any fuel stabalizer in it either.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Nov 22, 2009 | 08:20 AM
custom240sx's Avatar
DC Crew Member #1
I'd be more worried about the condition of the tank. You can stick a large magnet down in there and have the magnet taped to a stick. Swish the magnet around for a little while and it will collect quite a bit of the stuff. We went and bought 5 gallons of 87 octane and kept swishing it around and dumping it out until the gas came out clean.
