idle problem
Old Nov 8, 2009 | 07:33 AM
thavone's Avatar
Default idle problem
ok one day i was just driving home for work and the engine turned off, so i pulled over. then i start the car up it started to putter and it doesnt let me rev pass 3k rshared_pm and it putts all the way to 3k rshared_pm. does any one know about this problem? i change the ecu, distrubtor, map sensor with my buddys car and still the same problem
Old Nov 8, 2009 | 03:46 PM
mtber's Avatar
Is your check engine light on ?
If so, what codes is the vehicle throwing ?
Your problem may need to be troubleshooted in person. Contact a reputable honda/acura shop.
Old Nov 8, 2009 | 04:18 PM
thavone's Avatar
no check engine lights
Old Nov 8, 2009 | 04:26 PM
mtber's Avatar
I would suggest completing a compression & a leak down test on the motor.
Old Nov 9, 2009 | 11:18 AM
mogo21's Avatar
check ur idle air control , thats what it sounds like it could be
Old Nov 9, 2009 | 02:26 PM
thavone's Avatar
i already change the idle air control. im changing the TPS next when i have free time one friday.
