Will Bad Clutch Effect Engine Starting?
Old Nov 4, 2009 | 11:43 AM
Michael.'s Avatar
I'm a Photographer!
Default Will Bad Clutch Effect Engine Starting?
As the title states, will it? My guess is yes, but want to double check because I know my clutch is getting bad (I feel like I don't know how to drive a stick because starting in first gear is so bad with clutch chatter).
I have a CEL but I was thinking it was for the o2, haven't scanned/checked the code yet, but will soon to see if there's anything else...
Nikon D300 | 10-20 | 18-50 2.8 | 70-300 VR | 50 1.8 | 80-200 2.8
Originally Posted by Petitt
Please take a look at our Photography section with your friend, and take some notes.
Old Nov 4, 2009 | 12:31 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
how is it not starting? is it spinning over?
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Nov 4, 2009 | 12:41 PM
Kung.'s Avatar
no, the bad clutch shouldn't affect staring the engine.
Old Nov 4, 2009 | 12:48 PM
CRAWFORD BUILT
as long as it's not seized up in any way it shouldn't.
CRAWFORD BUILT
DC Crew Member #23
Old Nov 4, 2009 | 12:55 PM
Kung.'s Avatar
yeah, I was also going to say if it isn't stuck to the flywheel too.
Old Nov 4, 2009 | 01:33 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
LOL
Do you not know how a car with a manual transmission starts/works?
-Winston Churchill
Old Nov 4, 2009 | 01:54 PM
Michael.'s Avatar
I'm a Photographer!
Yes I do. I was having a moment and over-thinking things. Needless, I know the clutch is bad and chatters and just sucks period.
When it starts, it is barely doing so, it's slow to start and take a few more times than it should to turn over. And then once it turns over its like hesitating and I have to tap the gas a little bit...It is a starter problem then? It has a new fuel filter, is it time for a pump too?
Old Nov 4, 2009 | 05:43 PM
CRAWFORD BUILT
no the clutch won't cause it too hesitate, that sounds like shitty plugs or bad o2 sensor.
CRAWFORD BUILT
DC Crew Member #23
Old Nov 4, 2009 | 05:53 PM
CRAWFORD BUILT
that was "sarcasm" above...
CRAWFORD BUILT
DC Crew Member #23
