obd0 car with obd1 dizzy
Old Oct 30, 2009 | 08:47 PM
honda_acura_dude's Avatar
Default obd0 car with obd1 dizzy
i got a b16 in a ef si..its got obd1 dizzy on it..i allready have the jumper harness to plug it in..my ? is do i have to have a obd1 computer to run it or can i juss use the stock obd0 computer..i juss need to be able to run..dot need vtec yet or anything...juss run..any help thanks...
Theres Only One Way To Build A Car..Build It Right!
Old Oct 30, 2009 | 09:11 PM
custom240sx's Avatar
DC Crew Member #1
Will not run...teeth count is different than obd0 therefor computer will read incorrectly and could possibly damage your motor.
Old Oct 31, 2009 | 08:22 AM
so best thing to do now would juss run a obd0 dizzy on it untill i can get the computer jumper harness?
Old Oct 31, 2009 | 08:39 AM
rangcrx's Avatar
engine building &best
what computer is in the car now?if its a p28 then its been converted to obd1 already if its a pr3 then its obd0 buy a crx si distibutor and cut a leg off and run it like that no need to convert a stock b16 to obd1
i love AUTOZONE
Old Nov 1, 2009 | 02:10 PM
sullivanracing06's Avatar
ive got a obd1 dizzy thats has obd0 harness soldered on it so itll plug directly into your obd0 engine harness
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Nov 1, 2009 | 02:34 PM
DC Crew Member #1
^ He can only do that if running an obd1 ecu...I believe he is running and obd0 ecu and has an obd1 dizzy that he was asking if it will work with his obd0 ecu.
