1992 acura integra starting problem
Old Oct 20, 2009 | 03:21 PM
chondacrx's Avatar
gangster
Default 1992 acura integra starting problem
i have a 92 acura integra 2 door, auto. every time i try to start the car a relay behind the cd player clicks. does anyone no if the relay is messed up or is it something else causing it. the relay isnt real big.... thanks
Old Oct 21, 2009 | 02:44 AM
chondacrx's Avatar
gangster
someone help me out
Old Oct 21, 2009 | 04:11 PM
chondacrx's Avatar
gangster
anyone
Old Oct 21, 2009 | 08:56 PM
StreetBlitz's Avatar
B Tuned CRX
main relay is inside the cd player. needs to be changed.
Old Oct 22, 2009 | 01:09 AM
chondacrx's Avatar
gangster
its not the main relay that clicks. its the other smaller relay that clicks. i think its called the starter relay. would the main relay make the other relay click.
Old Nov 17, 2009 | 04:14 PM
AccordMike92's Avatar
Yoo!!!!!
Old Nov 21, 2009 | 05:06 PM
db2gsr's Avatar
relays always "click" when theyre working its, when it doesnt that you really need to worry about them
Old Nov 21, 2009 | 05:11 PM
db2gsr's Avatar
a relay is a mechanical device that uses magnetism to close contacts which makes the "click" noise that you hear thus supplying power or ground to the unit that it is controlling
