Ignition timing/cam timing and idle problems
Old Mar 31, 2002 | 08:50 PM
99B16Si's Avatar
ever since ive been screwing with my timing my car has been idling really rough sometimes barely holding on. my vacuum is normally about 18-20 at idle and is now around 15 for some reason with a normal rpm idle(700-800). my timing is at 10-11 degrees right now. i also screwed with my cam timing.the intake cam is advance 1 and the exhaust is retarded 3. could either of these effect my idle that bad? thanks for any help
Old Mar 31, 2002 | 09:50 PM
Matt Vassallo's Avatar
lifelong learner
you are increaseing your valve overlap mang
if you make the intake open earlier
and the exhaust open later
that means
the exhaust will stay open alter and the intake will open sooner and there will be even more increased overlap
rest in peace tim.
Old Mar 31, 2002 | 09:51 PM
lifelong learner
i am totally out of it and i no longe rhave spikey hair so anythign i may have said could be wrong
rest in peace tim.
Old Apr 1, 2002 | 05:57 PM
Bill's Avatar
Livin' in Seattle
Originally posted by "Someone"
both have a direct effect on idle and youve already diagnosed your problem. If you want it to idle like it did before set em back and then take the car to get tuned. Seat of the pants dyno tuning aint gonna cut it.
Old Apr 4, 2002 | 07:40 AM
99B16Si's Avatar
true it will come soon i just need the funds.
