SOHC people! ever put a y8 mani on a z6?
just picked up a y8 manifold today and i know that you can mount it on a z6 no problem BUT is there a DIY anywhere? The 3 or 4 I have found are "page cannot be displayed" or the pictures are little red X's, or just not detailed enough.
if anybody has done this swap over before i had a few ?'s: 1. do you need a y8 fuel rail? 2. i wanted to get a bigger tb, since the z6 is only a 56mm i wanted to upgrade to a b series one 60mm , anybody know of a certain tb that the holes line up? rep will be given and answers will be much appreciated. thanks. Slocivic |
DIY D16Y8 intake manifold onto D16Z6 write-up how-to LOTS OF PICS!!! - Honda-Tech
The pics are gone from the link but the step by step is their. Any throttle body for an H series B series or D series are interchangeable, with one catch; you need to pay attention to where your IACV (idle air control valve). Also make sure when you add the larger throttle body that you port match |
much appreciated, thank you.
when i put mine on ill do it with pics, and make a write up |
