TR I need Help, Car won't start
Old Sep 23, 2009 | 09:52 AM
teg's Avatar
teg
Default TR I need Help, Car won't start
Ok TR, my daily driver is a 96 acura integra 4 dr, stock everything, and auto.
Car ran ok at times and sometimes car would jerk while driving like bogging down. Changed fuel filter, fuel pump, cleaned injectors and put on new o rings, checked all fuel lines and seems to be fine.
Over the weekend the motor was shaking really bad, I was able to make it home (10 mile drive), parked it in the drive way. came out to check it the next day, now it won't start. It cranks but won't start.
So, then I changed the o2 sensor before the cat, now even changed the dizzy, dist. rotor, cap, spark plug wires, and plugs. I checked and it gets spark but motor not starting. Also I can smell fuel when trying to start up the car too.
I searched online and some say that it could be the TPS. I don't wanna throw more money into things that I don't need. Please help me if anyone knows. Thanks!
Also, the cel was blinking before the motor died, can't check the code, don't have a scanner. I checked the timing belt, alls fine, and TDC.
Old Sep 23, 2009 | 02:45 PM
teg's Avatar
teg
just tested the tps with my multimeter and its good. Sprayed carb cleaner into throttle body and cleaned it, tried starting with starter fluid being sprayed into TB, still not starting. WTF can be wrong?
Old Sep 23, 2009 | 03:52 PM
Old Renegade's Avatar
Cool Runnings
timing may be off.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Sep 23, 2009 | 07:14 PM
teg's Avatar
teg
I had the timing checked last month before I started replacing stuff, it was good. I am stumped on this one.
Old Sep 24, 2009 | 06:36 PM
teg's Avatar
teg
rechecked timing and its on the dot, even tried another ecu and still nothing. Anyone got any ideas?
Old Sep 24, 2009 | 07:35 PM
Nandosol's Avatar
Garage Slut
try to pop start it
if it starts then its either your starter or battery
Old Sep 24, 2009 | 11:52 PM
cuban4l's Avatar
votaaaa mantecaaa!!!!!!!!
Originally Posted by Nandosol
try to pop start it
you sir are fucking retarted............ the car is auto.
Old Sep 25, 2009 | 04:33 AM
EGKID's Avatar
The tps is usually the cause of the shaking/jerking while driving, but I don't know if it'll cause the car not to start. Is there anyway you can try another throttlebody?
Ricky
Old Sep 25, 2009 | 06:54 AM
Nandosol's Avatar
Garage Slut
oh my bad didnt read that part
Im glad you could enlighten us with your intelligence. Oh wait, you had nothing constructive to say. Maybe you should shut the fuck up.
Anyway back on topic.
If it turns over check for spark, fuel, compression.
Old Sep 25, 2009 | 07:38 AM
teg's Avatar
teg
I get spark and fuel, tested the TPS already and still good. gettin frustrated, might just pull the motor and throw in another one, but I'm just afraid that if I do that, it won't start still. POS car, WTF!
