Strange noise
Old Mar 22, 2002 | 04:53 AM
Tits McGee's Avatar
is cooler than you
It sounds like something in my rear suspension is making this strange noise......its hard to describe without you actually hearing it....the closest thing I can come up with is like and whining owl-hooting kinda noise. Not really a squeek and not like metal on metal. Sounds like its from the driver side....makes the noise sometimes sometimes not. Last night a friend of mine sprayed every joint bolt bushing etc down with WD-40...didnt help. Could it possibly be the shock?? And if so is that bad??? Help!!! Its driving me fing crazy!
Old Mar 22, 2002 | 09:24 AM
Tits McGee's Avatar
is cooler than you
Anyone??? Please help its driving me insane.
Old Mar 22, 2002 | 11:14 AM
svtjesse's Avatar
Use lithiam grease on the bushing wd 40 does not work at well or last to long.
Jesse
Old Mar 23, 2002 | 07:14 AM
Tits McGee's Avatar
is cooler than you
Originally posted by "Someone"
Originally posted by zorro
my vote is the tire take the front wheels sawp them to the back see if it stops or changes . does the noise happen over bumbs or just flat ground at high rate of speed
It only happens over bumps.....not on flat/semi-flat surfaces.
R91Si
Sep 6, 2000 06:53 PM
