spark
Old Sep 20, 2009 | 03:32 PM
cabron's Avatar
Default spark
hey tr i have a crx with a ls it have new diz n new ecu but some times it pass spark but some time it does not what can it be
TR "eg" crew #37
Old Sep 21, 2009 | 04:13 AM
96spydergst's Avatar
Default check
Check your grounds, How old are your spark plug wires? Good spark plugs? The correct ones? If it is only running on and off it sounds like something is going out...Maybe the starter relay maybe your resistor box, There is tons of stuff it could be. Do some research on the thngs its doing.
I believe in a lively disrespect for most forms of authority.
96 eclipse gst drop top sold
98 civic EX sold
94 civic EX sold
94 cx H22A1 whippin
Old Sep 22, 2009 | 04:54 AM
cabron's Avatar
resistor box is new new spark plugs n wires new starter relay new ecu new main relay n i look it up but nothing is comeing up thank bro
TR "eg" crew #37
Old Sep 25, 2009 | 02:53 PM
onebadcoupe's Avatar
ok check the ground on the thermostat housing. but aside from that check the 2 bolts that bolt the thermostate housing to the block. if it shimmeys around at all you'll have those symptons
94 dohc vtec ej1 FS
https://www.tamparacing.com/forums/c...ml#post7081439
Old Sep 28, 2009 | 12:52 PM
cabron's Avatar
thanks bro
TR "eg" crew #37
