blockguard
Old Sep 19, 2009 | 05:57 PM
twisterman's Avatar
Default blockguard
Has anybody done a d16 turbo build without a blockguard,with 300hp.
Old Sep 20, 2009 | 01:16 PM
Spartan UT's Avatar
Bowley
my advice fucking get one cause if you do end up fucking up you walls its much more expensive plus if you do it later on then thats more money just to take the head off its much easier to put one on before you but ur engine back together unless it already is
My Sexy Car Her name is Isis "Greek for The Throne"
Robert better not get in my face... 'cause I'll drop that motherfucker!
You're a big, fat, curly-headed fuck!
Suppose Nancy sees me coming out of the shower and decides to come on to me. I'm looking good, got a luscious v of hair going through my chest pubes down to my ball fro. She takes one look at me and goes " Oh my god, I've had the old bull now I want the young calf" and grabs me by the weiner.
Old Sep 20, 2009 | 02:10 PM
YARO's Avatar
Smith & Wesson Protected.
They are a waste of money and even the people that make them agree. If you do end up getting one make sure is pressed in before you bore and hone the block. Cause the installation process tends to "egg" shape the cyl cause of the tight fit.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Sep 20, 2009 | 02:32 PM
rangcrx's Avatar
engine building &best
^his right you have to have the engine honed again after you install it.i have only done 2 turbo sohc motors i myself use a blockguard in every motor"thats not stockrebuilt" building a sohc for turbo sucks.buy a ls motor..unless you find a old set of the eagle rods with the Edge sloped and 5/16bolts then you will need to cut the block"also has to be done b4 honeing/boreing"
i love AUTOZONE
Old Sep 20, 2009 | 03:01 PM
twisterman's Avatar
Why does a sohc turbo motor suck,what happened.
Old Sep 20, 2009 | 03:30 PM
Alpha's Avatar
Honestly I have had good success without them and with them installed correctly. They need to be welded in right below the cylinder sleeves and cylinders bored/honed
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
