d16 turbo needs more power
Old Sep 16, 2009 | 08:52 PM
imakemoney85's Avatar
Question d16 turbo needs more power
d16y8 all stock except for turbo running 7lbs, skunk2 longtube intake,fuel pressure regulator ,cold air intake, 5zingen exhaust
car runs better when at 5lbs then 7. its set up for 7 but i ease the pedel to 5lbs and she goes better. also a/f guage drops to very left and light sits at lean low side after highway driving but works around town. i'm thinking o2 sensor what about you guys. and got electronic boost guage and mechanic said i need bigger injectors because of something wit fuel pressure regulator and injectors being held open at certain boost and thats it. I need some more info about this too . need the help and have about 1000 to shop wit and can do most things
turbocharged
Old Sep 16, 2009 | 08:58 PM
Nandosol's Avatar
Garage Slut
you need to have someone tune your car after you get an EMS or ecu socketed/chipped with the right program/maps
get a wideband o2 sensor and gauge
That narrowband is just a glorified christmas light
If not done correctly your motor will end up with a nice hole on the side or scarred internally
Old Sep 16, 2009 | 10:23 PM
sullivanracing06's Avatar
agreed, a narrow band is a waste of 30 bucks, loose the narrow band and see how far off your afr really is
Sullivan Racing LLC
352-665-2496-Tom
SullivanRacing06@aol.com
my lag is your courtesy head start
ATTENTION.... installing a head gasket, head studs or pistons and rods in your otherwise STOCK engine dose not make it a "built" engine! stop listing you cars for sale saying they are built when its not!!
Old Sep 17, 2009 | 05:18 PM
FrodoGT's Avatar
Found the Vtec switch.
Please tell me you are NOT boosting on stock injectors... thats a horrible idea and asking for scrap metal..
You need bigger injectors and to tune the car, and what turbo is it? because itll probably handle more than 7 psi unless its a large turbo.
TR Old Skool EF Crew #24
Old Sep 18, 2009 | 05:35 AM
Alpha's Avatar
You need the following ...
* Chipped, socketed and datalogging ready OBD 1 ECU
P05 : 92-95 OBD-1 Civic CX (D15B)
P06 : 92-95 OBD-1 Civic DX (D15B)
P07 : 92-95 OBD-1 Civic VX (D15Z1)
P08 : 92-95 OBD-1 Civic/CRX VTi/VXi (sohc vtec)
PR4 : 92-93 OBD-1 Integra RS/LS/GS (B18A)
P28 : 92-95 OBD-1 Civic Si/Ex (sohc vtec d16z6)
P61 : 92-93 OBD-1 Integra GSR (dohc vtec b18c)
P71 : 92-95 OBD-1 Integra (sohc vtec d16a)
P72 : 94-95 OBD-1 Integra GSR (dohc vtec b18c)
P74/75 : 94-95 OBD-1 Integra RS/LS/GS (b18b)
* OBD2 to OBD1 conversion harness
* Bigger injectors (440CC MINIMUM)
* Bigger fuel pump (Walbro 255hp)
* A tune
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Sep 19, 2009 | 04:42 PM
FrodoGT's Avatar
What he said. And thats just the cheapest route to not blowing your engine (but hell, its a y8..itll spin a bearing soon anyway) There are lots of other tuning options available as well, in addition to the socketed stock ecu.
Old Sep 19, 2009 | 08:53 PM
custom240sx's Avatar
DC Crew Member #1
...good luck
Old Sep 19, 2009 | 10:55 PM
CARTER's Avatar
Hmm, Hondata s300 or aem ems 550 injectors and 255lph pump! Thats the way it should be done.
BMW FTW
Old Sep 19, 2009 | 10:58 PM
Jspec94LUDE's Avatar
ROLLIN UP STANKY!!!
+1 for alpha he took the words rite out of my mouth
Old Sep 19, 2009 | 11:01 PM
CARTER's Avatar
Oh and trash the garbage narrow band! Burn a hole in the piston or valve gauge! get something u can really use for a/f
BMW FTW
