tranny help for civic
Old Sep 9, 2009 | 05:19 PM
Dev Si's Avatar
Civic Si
Default tranny help for civic
Would a 92 tranny from a 1.5L that is standard work on a 96 1.6L.
Old Sep 9, 2009 | 05:51 PM
tai mishuu911's Avatar
rut roh
both d series, yes
N/A GSR on its way.
StricKly MT 727-510-6301
WIREWORX 407 388-5809
Old Sep 10, 2009 | 02:43 PM
Dev Si's Avatar
Civic Si
Originally Posted by tai mishuu911
both d series, yes
would the shift linkage work as well or will i need to get a new shift linkage, also when changing out the tranny would I need to get a clutch alingment key or no?
Old Sep 14, 2009 | 07:31 PM
thegoldenchild's Avatar
linkage works fine and u dont need a clutch alignment tool unless u replace the clutch
Old Sep 16, 2009 | 09:44 AM
On some trannys there is a letter next to the tranny number.
If those numbers don't match, the pilot shaft won't fit.
Example: If that letter is an "E" whatever you put in
must be an "E" also.-Bob
Old Sep 16, 2009 | 05:20 PM
Dev Si's Avatar
Civic Si
thanks
