F22/H22A Swap Questions...
Old Sep 6, 2009 | 06:56 AM
sxysweed's Avatar
CRX.XXX
Default F22/H22A Swap Questions...
My dad approached me about him swapping a H22A (automatic) into his 93' Accord. Since it would basically drop in (it's a F22__ stock). Which means that I have a F22 to play with/rebuild/auto to manual swap. Or F2B/D possibly. Anyways, a few questions regarding both..
1.) Tiger Japenese Imports. Anyone have any experience with them? Good/bad?
2.) What ecu to use for a H22A?
3.) Any thoughts on a H22A out of a 92-95 prelude swap?
4.) Any weak spots on teh H22A?
5.) Can any power be had out of the F22Bx (I think)?
6.) Is there any mini-me style headswaps for teh F22's?
7.) Is it even worth building and doing the work to drop it into a CRX?
Thanks, I'm working on doing the research, just thought it's easier to post this first.
Oh, and the engine he's looking at is this one:
Tiger Japanese Auto Parts LTD - H22A OBD1 DOHC VTEC Engine Automatic Transmission 92-95
Old Sep 6, 2009 | 07:25 AM
custom240sx's Avatar
DC Crew Member #1
Tigerjapanese is fine to order from...got 3 motors from them.
Old Sep 6, 2009 | 08:29 AM
SiR-Drew's Avatar
Default info....
ok here we go, lets see if I can help ya out a bit....
1. I've heard mixed opinions about tiger japaneses imports
2. The P13 is the stock ecu for the h22a... though a P28(civic ex), P72(intera gsr), or a P30 (b16 civic del sol) will all work.
3. an H22a out of a 92-95 Prelude would be your best bet because it is an obd1 motor, after 97 they are obd2... and not really worth the hassle of converting your OBD system
4. The only "weak" spot on the H22 would have to be the FRM sleeves, but thats only considered a weak spot if your intending on adding boost to the motor, the FRM sleeves typically only hold about 8 pounds of boost before they crack. I'm sure some people on here have put more boost into one with the proper tuning, but it's not recommended. Also in order to use aftermarket pistons you either have to use the Mahle Gold pistons... or resleeve your block.
5. Plenty of power can be had out of an F series block, add a turbo on it and ZOOOM! The F series blocks looove boost because they have a lower compression and cast iron sleeves that are said to hold 20+ lbs. of boost safely. If you decide to go all motor, check out www.bisimotor.com
He currently holds many world records for the all motor/pro stock naturaly aspirated SOHC Honda engine (F22a)
6. Yes, the F22a4 has a VTEC head, and it can safely be installed onto an F22a1 block... there fore being a simple mini-me swap. Also, with a little bit of work, an H22a head can be installed to a F22a block. All you have to do is block two oil return lines on the head, fashion an H22 water pump gear onto an F22 water pump housing, and get an H22 timing belt. I have done all the custom work to build the illusive "G22 Vtec" but I havent put it into a car yet. Got distracted by my new build =P
7. "Is it even worth building and doing the work to drop it into a CRX?"
If your talking of putting the H22 into the CRX then HELLS YES!!! That would be one insanely fast Rex and you would be kicking alot of ass around town and on the track... if you could get it to keep traction that is. If your talking of putting the F22 into a CRX, then your still talking about a 120hp motor 135 ft. lbs. of torque into a car that typically only comes with a D series motor putting out about 100 hp. or so.... so yeah it would still be nasty.
Hope this helps with your build my friend.
-Drew
Old Sep 6, 2009 | 09:49 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
I've never heard anyone say that a car with 120hp is nasty.
Only on TR .
-Winston Churchill
Old Sep 6, 2009 | 09:59 AM
SiR-Drew's Avatar
Only on TR .
lol, true that. I figured someone would have some bashing to do. Can't post anything productive, so why not stomp on someone else's post.
Only on TR
Old Sep 8, 2009 | 05:49 PM
ProvenPower's Avatar
The F22 is a pretty strong motor actually. One of the guys at our shop has one boosted to about 18lbs and he putting down about 300 to the wheels and has great torque. Its pretty quick ins a 94 accord coupe and I can only imagine how fast it would be in a CRX. He is going to raise the boost but he needs a new boost controller. He just bought another f22 and is planning on building that one up to swap into his current car. The one in the car now is all stock except for the turbo kit and injectors. Once he's got the other one built he's going to boost the shit out of the one he has now until it blows to see what the stock motor is capable of.
Anyways, if your going to do the H swap it will be nice. But I would take the F and put it in the CRX and boost it. I believe that you can use stock DSM manifolds on the F. It would make it a pretty cheap option for turboing. Find someone who has upgraded their Evo and buy their old setup. You can use their injectors also.
Are you going to be doing the swap yourself or do you need someone to do it. If you need someone to do it we could help you out. If you want, stop by the shop some time we are actually finishing up an H swap in a 96 accord right now.
WWW.PROVENPOWERTAMPA.COM
813-988-3966
ECU Socketing, Custom wiring Harnesses, Stereo, Alarms, Navigation, Electrical Troubleshooting, and More!!!
Old Sep 8, 2009 | 08:10 PM
sxysweed's Avatar
CRX.XXX
Thanks for the response.
I've been looking into the F-swap. Seems the tranny is less than ideal and putting in a cable shifter seems like a PITA. And a F2D kit is around $1000. So it's like $1500 to drop it in, stock F22 and D16 tranny. Idk, just exploring my options.
I'd be doing it myself. Build the engine in my dorm (be interesting to explain to my dormmates) and then drive it home and swap it in my dad's garage. Thanks for the offer though.
Old Sep 9, 2009 | 07:50 PM
No problem. Just trying to help
813-988-3966
