questions bout an jg built head and block
Old Aug 27, 2009 | 07:19 PM
305civicboy's Avatar
Default questions bout an jg built head and block
hey i was a question i might be getting an built head from jg its ported and polished and has stg2 crower cams and full crower valve springs and retainers and the valve are 1mm bigger and i might be getting it for 1000 dollars but i was going to get an GSR block wut pistons and rods should i get it. i have an ls b18b with an 60-1 t4 turbo and a ram horm manifold but i am getting and new manifold to fit the gsr head to and im using the same turbo set up but i just need so suggestions for the block...i want to make around 350whp with the set up i got so just let me know what you guys think...thank you
Old Sep 5, 2009 | 08:35 AM
MightyMaxGS-T's Avatar
last setup i did on a honda with a 60-1 and built bottom end made 598whp, i was helping my cousin and his friend in ga. It was a LS/V setup with je pistons and eagle rods and the same ram horn manifold ur using.
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Sep 5, 2009 | 08:46 AM
rangcrx's Avatar
engine building &best
^im with him dont waste it on the head build the bottom.altho 598whp is alot to me so i would shot for your 350goal
i love AUTOZONE
Old Sep 5, 2009 | 08:48 AM
lol rang everytime i see you post its like you are always agreeing with me or im agreeing with u...
