Car will not prime!
Old Aug 4, 2009 | 09:19 AM
Leem21vtec's Avatar
Default Car will not prime!
Ok here is the scoop, when I 1st turn the key right before i start it the check engine light comes on and doesn't go off until the fuel pump begins to prime, correct? Well my car especially when it rains will not prime for as long as 45min at times. This makes me so off schedule when I can just hop in and go I have to wait for the cel to go off to start. So i have to sit there and wait until i hear the click and then the prime. Once it starts it runs good like it is suppose to. I noticed after driving for a little while it doesn't take as long to start/prime. I have checked and replaced main relay, inspected all alarm wires. I am thinking it may be a distributor problem or a fuel pump sending unit. Any Ideas or advice we be greatly appreciated.
TR "Old Skool DA" Member #80
Old Aug 4, 2009 | 09:51 AM
Nandosol's Avatar
Garage Slut
main relay?
Old Aug 4, 2009 | 10:16 AM
YARO's Avatar
Smith & Wesson Protected.
I had this problem and it was the main relay.. When it happens smack the relay and the cel should turn off and the car should start..
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Aug 4, 2009 | 11:24 AM
Leem21vtec's Avatar
yeah i tried that. I actually put one in from my friends car and it still didn't go off. Unless his is bad too.
Old Aug 4, 2009 | 12:40 PM
Nandosol's Avatar
Garage Slut
fuel pump/wiring
Old Aug 4, 2009 | 12:45 PM
FC_V8's Avatar
Sounds like main relay like stated above. Make sure you are swaping out the correct piece. It has a 10mm nut holding the relay to the car.
Old Aug 4, 2009 | 12:48 PM
Old Renegade's Avatar
Cool Runnings
May be the main fuse in the engine bay where the battery wire goes to.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Aug 5, 2009 | 12:58 PM
Leem21vtec's Avatar
ok gonna check all of that. Dont think its the wiring though. Never did this all the time, started acting up about 2 months ago and getting worst.
Old Aug 5, 2009 | 05:09 PM
Cool Runnings
^mainly was stating that the fuse may be blown.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Aug 6, 2009 | 10:14 AM
Blue92ludesi's Avatar
wheres it located
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
