HELP PLEASE integra starting problem
Old Jul 27, 2009 | 07:30 PM
owl's Avatar
owl
Default HELP PLEASE integra starting problem
bought a 95 integra ls about 3 weeks ago replaced the battery alternator and some other little things. it was running fine for about a week, and two days ago it was taking it a little longer to crank then usual. when i tried to leave work today it wont start. it will turn all the way over but wont make any noise. i push started it and it started right away and ran fine all the way home. when i got to my driveway i turned it off and tried to restart it, same thing all the way over no crank sound. help me please its my daily driver and i gotta get to work or im screwed
Old Jul 27, 2009 | 07:42 PM
CivicCX's Avatar
....sounds like your battery. Your alternator probably is not charging the battery.
Old Jul 27, 2009 | 07:49 PM
owl's Avatar
owl
that was my first thought and i tried jumping it. left it on charge for like 20 min still no crank. plus i have bright lights headlights radio everything. and if it was the alternator im pretty sure it wouldent have held charge long enough to get it home cause i work 20 min away. any other suggestions
Old Jul 27, 2009 | 07:53 PM
CivicCX's Avatar
check your grounds...specially the one on the thermostat .....
Old Jul 27, 2009 | 08:02 PM
owl's Avatar
owl
there all good
Old Jul 27, 2009 | 08:19 PM
turboT727's Avatar
LScivic727
what type gas you put in it?
Old Jul 27, 2009 | 08:33 PM
owl's Avatar
owl
regular
Old Jul 27, 2009 | 08:36 PM
Old Renegade's Avatar
Cool Runnings
check the connections to your starter. especially that little push on wire.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Jul 28, 2009 | 04:49 AM
CertEmt's Avatar
^^ That was one of my problems, but the same thing happened to me in my Teg Im no honda tech but, check all your wires and grounds check fuse, and look at the wires near the fuse box under the steering wheel near the clutch, I had bad wiring, that made my car not start unless I moved the wires around. Some times it still wont start but I know its that wire and I jiggle it (no homo) and it starts, hope this helps GL.
