I Need Stiffer Springs !
Old Feb 21, 2002 | 08:41 PM
88EFSiR1J1's Avatar
Right now I have a set of suspension tech springs good springs for a compfy ride but far to loose Ive been banging the hell out of my header and I need something stiff was looking into H&R sport springs because I know these to be tight but is there anything tighter? nothing to crazy low cause I was looking into a 4-1 header. Im also using KYB GR-2 shocks.
-Todd
88 Civic Sedan cardinal metallic red
" I am so dirty...On the inside " - Trent Reznor
14.729 @ 94.79
60' 2.424 ( Pep-Boys Tires!! )
Old Feb 21, 2002 | 08:43 PM
88EFSiR1J1's Avatar
Thanx Ill look into those
14.729 @ 94.79
Old Feb 22, 2002 | 05:37 AM
Bill's Avatar
Livin' in Seattle
If you dont want to go the coilover route just call up Eibach and get a custom set of springs. All you need to know is spring diameter height the spring rate you want and whether it be linear or progressive.
In fact thats basically all GC coilovers are youve just got a custom sleeve and then you pick out your own set of springs to go with them (Eibach by the way).
Old Feb 22, 2002 | 07:58 AM
88EFSiR1J1's Avatar
Originally posted by "Someone"
Originally posted by RavageEJ6
well if they werent such a drop id say
neuspeed race
but thats too low for what u want
we know i had the stiffest sup.
Well then why not neuspeed sport? the problem is that most sport springs arent as tight as their race springs
14.729 @ 94.79
Old Feb 22, 2002 | 02:37 PM
b16aRacer's Avatar
Moon Equipped
Neuspeed = the suck.
i had sports on my car just took them off today -- car handles better stock in my opinion. Theyre pretty soft. I would go with the G/Cs or Eibachs like Bill said. Cant go wrong w/ Eibach.
Also you may look into a sportier strut-- they have as much to do w/ handling as youre springs do if not more. Konis are good so are AGXs but not for more than 1.5 drop i hear.
Good luck either way.
'00 FBP Si
Sebring rule in effect
BlackMax97se
Nissan/Infiniti Tech
Aug 9, 2000 01:04 PM
