speedometer won't work
Old Jul 14, 2009 | 05:10 PM
Wanting That HONDA!!'s Avatar
Default speedometer won't work
alright speedometer isn't moving. My friend told me it could be my speed sensor. how do i install the speed sensor?
theres two bolts on it, i remove em and i twist off the speed sensor. how do i put it back on correctly?
Old Jul 14, 2009 | 05:11 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Twist it in, install bolts, plug in sensor.
-Winston Churchill
Old Jul 14, 2009 | 05:41 PM
1camsol's Avatar
Only a single cam brotha!
well said.. +1 lmao
Old Jul 15, 2009 | 12:57 AM
Is it electrical or cable?...-Bob
Old Jul 19, 2009 | 05:32 PM
ASars's Avatar
yup its easy its right on the tranny
ASars
SGT. U.S. Army
Old Jul 19, 2009 | 06:37 PM
Default Installing An Electrical Speed Sensor.
Lucky break. Electrical sensor.Remove old one, put the new one in it's place.-------------------------------On some cars, there is a short metal pin that fits into the tranny.grease it well and the friction of the grease will hold the pin in place, so you don't drop it as it goes back in.Some cars have a small gear (grease it well) and it will rotate as it goes back in.You will know the sensor is back in far enough when you can press the sensor flush against the tranny. Gasket should line up easily.I put a drop of loctite on the bolt's tip for the ones I fix at my place so the bolt won't work looseand it doesn't get overtight. -Bob
Old Jul 20, 2009 | 12:36 AM
custom240sx's Avatar
DC Crew Member #1
There is an o-ring gasket on it..lube it with some old motor oil. Just play with it trying to slide it back in at different positions (spinning it) and make sure it is straight up and down. Sooner or later it will pop in.
