Help me Re-Do my fuel lines.
Old Jun 13, 2009 | 10:52 PM
TurboJdmEk's Avatar
is on blocks...
Default Help me Re-Do my fuel lines.
i am deleting my oem fuel filter and replacing my banjo fittings and lines with regular rubber hosing and barbed fittings. i plan on using a fuel filter like this one... Spectre 2369 woud something like that work?
its coming...
Old Jun 13, 2009 | 11:38 PM
00vtecsi's Avatar
slow ass car
i'ma save u from alot of trouble, and possibly your life, lol. if i really need to replace your fuel lines, use steel line and a inexpensive, High Pressure inline filter, easy to find a a parts store. that filter is only good for maybe 15 lbs pressure, and not that great of a filter, that and rubber hose wont hold up well, and can easily get pinched off, and/or ripped and torn off. if u must use hose, use as little as possible. hope it helps....
HELP:https://www.tamparacing.com/forums/h...er-fender.html
-Tuned Performance-/---------------------------------CentralForidaAutowerks ----->660sw 13th st. ocala<------JJC autoworks--shop forum
tuning,turbo installs,custom wiring tucks, nitrous systems, engine swaps,ecu's,engine building,much more, some of the cleanest, most affordable work around 352-857-2715 jason....
Old Jun 13, 2009 | 11:46 PM
TurboJdmEk's Avatar
is on blocks...
so no go on the rubber hose? WILL it work or as soon as i start the car is the fuel filter going to explode? i want this for ease of access and price.
its coming...
Old Jun 14, 2009 | 05:48 AM
DemonCivic's Avatar
The factory designed the filter and lines to work as is. There is no need to change anything, leave it as it was intended to be.
Old Jun 14, 2009 | 08:13 AM
TurboJdmEk's Avatar
is on blocks...
but it looks ugly, i want to switch it up to a cleaner look and hide it behind the intake manifold. besides someone already cut my oem fuel line between the filter and rail...
its coming...
Old Jun 14, 2009 | 08:25 AM
chi town brat's Avatar
! Ne shab'rud'ni !
Moved to the correct forum.
chi town brat
S Mod
Old Jun 14, 2009 | 08:37 AM
Tampa's_Slow_EG6's Avatar
Living in Black & White..
so get another one they are really not hard to find.. get a brand new oem fuel filter and call it a day.. btw its really not gonna look all that clean, cuz you still got the clutch lines, vacuum, so on and so on.. so its really not gonna make a diference.. but anyway to each there own..
Old Jun 14, 2009 | 07:04 PM
YARO's Avatar
Smith & Wesson Protected.
If tuckin is what you want do steel braide lines and AN fittings. Do NOT convert them to rubber hoses on High the pressure/feed line. <thats asking for trouble.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Jun 14, 2009 | 08:14 PM
TurboJdmEk's Avatar
is on blocks...
k thanks guys
its coming...
