93 Prelude engine swap options
Old May 27, 2009 | 02:32 PM
UtilityCow's Avatar
Default 93 Prelude engine swap options
I'm looking at a 93 Prelude SI 5 speed that needs an engine. I need to get an idea of what it's going to cost to get this thing on the road before I purchase. I did not get to look under the hood or hear it run. The owner says it sounds like a rod knock. I know very little about Hondas so I need some help finding a replacement motor or short block. I don't think rebuilding is an option because I want this on the road quick. No wiring or computer changes unless very minor and cheap.
What engine is in the SI? I ran the vin and it says 2.3L.
VTEC, non VTEC?
What short blocks or JDM engines would work?
What other vehicles should I be looking at in the junk yards?
I want to spend as litttle money as possible. This will not be a ricer. I'm looking for a cheaper daily as my Benz requires 93 octane and it's already at $2.70 and I'm driving ALOT.
...at this time.
Old May 27, 2009 | 02:38 PM
1nycelude's Avatar
***boosted***
the motors are pretty cheap, you would want to look for a h23 that would be the stock replacement engine. or you could go with the h22 and have about 50 more hp. if you are serious i have a really good hookup on those engines and can install at a good price. pm me for details.
is it auto or manual.
i once felt bad cause i had no turbo!! then i met a man that had no VTEC.
Old May 27, 2009 | 03:47 PM
UtilityCow's Avatar
It's manual.
I'm all about more power, as long as it is an easy swap. I don't want to be chasing an ECM and rewiring.
...at this time.
Old May 27, 2009 | 06:38 PM
extatic002's Avatar
is an asshole
Yup the motor in the SI preludes are the H23 non vtec. The BB4 preludes also came with the H22 which is vtec and like ^ said it has like 50 more or so HP in stock form so obviously it costs more.
So in my opinion if you already have to swap the motor id say you should probably go with the H22 since its a better base to start with out of the 2. And since they came in the prelude stock you wont have any difficulty swapping the motor in there
Originally Posted by The Kyle
I quit every time I run out.
Then I quit quitting every time I get more.
Originally Posted by Clawhammer
As a general rule of thumb; if I can't fix it with a hammer it must be an electrical problem.
Old May 27, 2009 | 07:24 PM
UtilityCow's Avatar
Is that extra 50 HP at a cost? How do the torque curves compare? (I drove an SR20 for years) The wrench turning isn't the issue. I'm only concerned about having to chase parts. I'm going to assume that the harnesses and computers are different (between VTEC and non VTEC). This would have to be a quick swap project over a day or so.
...at this time.
Old May 27, 2009 | 07:30 PM
PooN_Lude's Avatar
Not the cheapest route, but probably the best road you could take..
Old May 27, 2009 | 07:34 PM
UtilityCow's Avatar
Okay... Going to call my junk yard buddy tomorrow. What are the years I'm looking for?
...at this time.
Old May 28, 2009 | 01:05 AM
Nandosol's Avatar
Garage Slut
93-95 obd I h22
The harness will be plug and play. The ECU will also be plug and play. You might have to run wires for vtec, I dont know much about Preludes. You might be able to search on honda-tech. If not search on google for someone that did a swap and see if they had to run any extra wires for a knock sensor of something of the sort.
Old May 28, 2009 | 01:17 AM
SuburbanNoize's Avatar
Cold Ass Honky
Your going to need to run a few extra wires to the Vtec Solenoid. I think its 2-3. Not very hard.
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old May 29, 2009 | 10:19 AM
UtilityCow's Avatar
Found a H23 from another SI 4WS locally. Probably going that route. Now I gotta haggle with the car's owner.
...at this time.
