ok so i ordered axles from hasport
well i ordered the h22 axles into the sol but it came with some instructions for installations but i can see the pictures on the instructions so is there a site i can go to that i can see it better? or does some1 know how to install them .. i thought you just put them on but you gotta do something befor installation thats all i kno lol ...
this is exactly what it says on the paper...
drive shaft shop h series axles.
over the years the h series axles have been prone to having inner boot failur due to the extreme angle they have to run at. we have left the small clamp loose so you can adjust the boot to the proper spot so the boot does not fail.
first you will need an end cutter style set of pliers, with the axle install in the car and the weight on the suspension (as it would sit on the street) adjust the boot so none of the boot ribs touch.
then with the end cutter pliers crimp the square ends of the clamp, make sure you don't over clamp it the sides that come together should not meet in the center. they should have about 1/8" in between the clamped end
you can get those pliers at autozone or discount. they're cv axle boot strap pliers.
"The richest man is not he who has the most, but he who needs the least."
TR "Old Skool DA" Member #28
