why is my b16 not starting
Old Feb 23, 2009 | 02:41 PM
ktmmatt231's Avatar
Default why is my b16 not starting
i got a obd0 b16a1 it has gas it has spark and it is timed last time it ran tho was b4 i put a new nead gasket can anyone give me ideas why it wont run o ya i checked the grounds and its not throwing any codes pm me if you know some reasons.
Old Feb 23, 2009 | 04:32 PM
Thatguysstuff's Avatar
Hey its that guy!!
compression check it??
Old Feb 23, 2009 | 07:54 PM
hondachris1994's Avatar
hatchback1994
how did u check for fuel and spark
Old Feb 24, 2009 | 05:07 AM
sprjit22's Avatar
Rick James bitch
It could be a number of things. If you need someone to come and take a look my number is in my signature
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Feb 24, 2009 | 07:54 AM
Janky99's Avatar
Honda Guru
Need more info.
-Did you just put the motor back together?
-Did you come out to start your car and it just wouldn't start?
-Was is running before? and what did you change to cause it not to run?
-What ECU are you running?
-Yr/Make/Model of the car its in
-Original wire harness? or ghettofied?
I could go on for days.. It's hard to analyze yor issue without the appropriate information.
Old Feb 25, 2009 | 02:03 PM
ktmmatt231's Avatar
i havent compression tested it i no that its geting fuel cuz the spark plugs are wet when i take them out after i spin it over the car was runing it just bluw a headgaskit and now it dosnt want to start its in a hf hb but i but a crx wiring harness in it and it has the same stock b16a1 ecu but i checked the and its good and not throwing codes
Old Feb 25, 2009 | 04:17 PM
civicized's Avatar
Fuel, and spark are all you need, providing it's sparking when the piston is in the right place.
Check your cam timing, and make sure it's gas that's making your spark plugs wet.
Old Feb 25, 2009 | 06:54 PM
StreetBlitz's Avatar
B Tuned CRX
he pulled the head....
TIMING
Old Feb 25, 2009 | 08:44 PM
quietflight6787's Avatar
is this in a crx? just curious
Old Feb 25, 2009 | 08:46 PM
SLOWIMPORT's Avatar
pshhhhhh bahbahbahbahbah
makesure you have your firing order right
TR "FIT" Member #001
