b16a1-a3 head on a b16a2 block?
Old Feb 8, 2009 | 08:47 AM
JDMAddict's Avatar
coolstorybro.
Default b16a1-a3 head on a b16a2 block?
will those heads work with a b16a2 block?
low is a lifestyle.
vimeo
flickr
Old Feb 8, 2009 | 08:59 AM
HonkeyDong's Avatar
Every dog has his day.
yes
Mattbuilt
AEM | Mugen | Skunk2 | Hasport | Hondata | Koni |Ground Control |
Old Feb 8, 2009 | 11:34 AM
JDMAddict's Avatar
coolstorybro.
alright, i was just wondering because im having some oil leakage coming around the head gasket area.
thanks.
low is a lifestyle.
vimeo
flickr
Old Feb 8, 2009 | 01:00 PM
Nandosol's Avatar
Garage Slut
Get a new head gasket then. You sure its your head gasket and not oil dripping down from your valve cover gasket?
Old Feb 8, 2009 | 03:50 PM
wolfenr1984's Avatar
Great White Hope
or oil leaking from the distributor hole due to a shitty o-ring
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Feb 9, 2009 | 03:49 AM
StrictlyBusiness's Avatar
Mr. Stealyogirl
+1 Dizzy seal or Vtec Solenoid I DOUBT its the headgasket.
www.jdmmindz.com
Lurkin' in a hood near YOU!
Old Feb 9, 2009 | 09:53 AM
JDMAddict's Avatar
coolstorybro.
i'm sure it's leaking from in between the head and the block. the block has a deck on it cause it's bored and stroked, so it has two gaskets, one in between the block and the deck, and one in between the deck and the head. but both head gaskets look like there fitting perfectly.
low is a lifestyle.
vimeo
flickr
