Need help D-series 93 civic speedo doesnt work
Old Feb 3, 2009 | 09:29 AM
primeredcb7's Avatar
I love Oral sex
Default Need help D-series 93 civic speedo doesnt work
like it says the guy who had the car before me said it didn't work and i wanna fix it and i dont know what the problem is? Their is 3 wires that come from the stock harness of color and he cut and replaced it with a different plug that are 3 different color then the stock harness NEED HELP PLEASE. ALSO is their a fuse for the speedo sensor. Cuz i was messing with it the other day and two wires touched while it was running and it blew my fuel pump fuse so i dont know
87 CIVIC SI HATCH--SOLD
89 ACCORD LX SEDAN--SOLD
90 ACCORD LX SEDAN--TOTALED
93 CIVIC EX SEDAN--TRADED
90 DX HATCH W/LS--TRADED
90 4-DOOR TEG LS--TRADED
93 CIVIC COUPE EX--SOLD
09 Mitsubishi Lancer--Current
93 JEEP GC 4X4--Sold
84 JEEP CJ7 4x4 w/ Chevy 1/2 ton running gear--SOLD
Old Feb 3, 2009 | 08:15 PM
343whpDelSol*'s Avatar
Holy hell i've answered this question alot of times on here! It runs through fuse 12 in the under dash fuse box if you dont have SRS, and fuse 24 if you do have SRS. Yours should have a yellow/blue wire running to ignition which changes to black/yellow in the grey connector on your driver side strut tower. It also has a yellow/white wire which changes to a yellow/blue at the same location. It also has a black ground wire which should ground at the bolt at the upper rad. hose
98 Eddie Bauer Explorer with single 12W7: 7th loudest vehicle in PA: Sold
93 Gutted Greddy Turbo and Zex Nitrous EG Hatch: Sold
07 Caliber with 13W7 and 20's: Traded
08 Ridgeline with all JL system: Traded
94 343whp D16z6 Del Sol: Sold
04 VW R32: Doin' Thangz
Old Feb 4, 2009 | 08:59 AM
I love Oral sex
well on my car it doesn't have a number 24 fuse. It stops at 23 is it one to the side
Old Feb 5, 2009 | 09:09 AM
I love Oral sex
hey
Old Feb 5, 2009 | 12:15 PM
Ok, i think i got your problem from those pictures you posted. This is how it looks to me: If you unplug the harness, and are looking at it with the clip on top, so the wires are away from you, and the side you plug into the VSS is towards you, were going to say 1 is left, 2 is center, and 3 is right. this is hard to explain on here so bare with me.
So it looks from the picture that a yellow/white wire is in 1, a white/black or yellow/black is in 2, and the green/white is in 3.
Again correct me if i'm wrong, but if thats right, then you'll need to connect the yellow/white to yellow/white.
the white/black or yellow/black on the VSS to the yellow/blue on the vehicle harness.
Finally the green/white to the black wire on you vehicle harness. I'm not sure what car that VSS is out of, but its no factory honda. But it looks like that will solve the issue, because its deffinatly wired up wrong
Old Feb 6, 2009 | 03:31 PM
I love Oral sex
thanks man i wired it up rite and i dont think the ground was being grounded so i ran an extra wire to the negative on the battery and put a fuse in number 12 and bam it worked thanks ALOT man
Old Feb 7, 2009 | 05:59 AM
Tampa's_Slow_EG6's Avatar
Living in Black & White..
lol if only mine was that easy to fix... who wanna come and fix mine my vtak does not want to pop...
Old Feb 7, 2009 | 02:41 PM
No problem man...glad i could help. and yes, ill pop the SHIT out of your veetech
Old Feb 7, 2009 | 03:22 PM
I love Oral sex
i have an extra sensor if you want it???
