HELP install my phantom grip
Old Jan 15, 2009 | 03:09 PM
isuzudubs's Avatar
Default HELP install my phantom grip
i have a phantom grip that i need put in my ys1 lmk
Old Jan 15, 2009 | 04:59 PM
Old Renegade's Avatar
Cool Runnings
not a good lsd in my opinion.
bump for help..
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Jan 15, 2009 | 06:10 PM
DemonCivic's Avatar
+1 i have seen many with problems, quaiffe is a better alternative
for installation contact neil sutton
Old Jan 15, 2009 | 08:34 PM
Cool Runnings
obx is good for a inexpensive unit. they have made all the necessary changes to make it a good product and resolve all previous issues they were having. to be on the safe side open it up inspect it for like stripped bolts and reversed spring washers. if it all checks out then you good for some two wheel grippin.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Jan 16, 2009 | 10:11 AM
isuzudubs's Avatar
thanks but fuck
Old Jan 16, 2009 | 04:42 PM
60-1EK's Avatar
Engineer at the source
They don't call it Phantom Slip for nothing.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jan 16, 2009 | 11:56 PM
FrodoGT's Avatar
Found the Vtec switch.
Phantom grip is not an lsd, its a set of blocks with springs that you jam into your oem diff to lock the wheels together with spring pressure. Although it may act as an lsd it is still just as weak as your oem diff and if your making enough power to need an lsd.. your making enough to shatter a few spider gears. Go with the obx, just check it first.
TR Old Skool EF Crew #24
