d series head q
Old Dec 18, 2008 | 11:48 PM
civic1994's Avatar
Question d series head q
witch d series vtech head is stronger d16z6 vs d16y8.....i have a d16y7 and want vtech like a crack head.how mutch would a swap like this cost?should i just wait for the b series swap?....really wantin b16a2sir. thanks all.....
Old Dec 19, 2008 | 03:30 AM
Skee's Avatar
b series
Custom high amp Alternators.. pm me
Old Dec 19, 2008 | 05:27 AM
00-Civic-Si's Avatar
Old Dec 19, 2008 | 08:23 PM
ProjectLife's Avatar
or just buy a y8 head for 150 bux put it on your y7 block until you get the bseries. the y8 intake manifold has better air flow.
Old Dec 20, 2008 | 04:31 AM
extatic002's Avatar
is an asshole
you really wont see to much of a difference if you swap the head on the single cam..So id say go with a B16 or B18 if you can afford it
*edit
And its VTEC damnit
Originally Posted by The Kyle
I quit every time I run out.
Then I quit quitting every time I get more.
Originally Posted by Clawhammer
As a general rule of thumb; if I can't fix it with a hammer it must be an electrical problem.
Old Dec 20, 2008 | 05:41 AM
BOB's Avatar
BOB
Too Old & Too Poor
They're both about the same. The z6 will flow slightly more, but on top of a stock block naturaly aspirated y7, you won't see too much of an increase. Check out D-series.org for more info. Cost wise, don't forget you will need a new intake manifold, gaskets, and labor if you're not doing the job yourself. (assuming the head you buy comes complete with a solenoid, and distributor)
Now rolling in a partial zero emissions vehicle.
