energy suspension question
Old Dec 18, 2008 | 07:14 AM
Yellow Rocket's Avatar
The Big Diehl
Default energy suspension question
A buddy of mine is selling this kit
HYPER-FLEX SYSTEM Complete Master Bushing Set Includes: front control arm bushings, front shock bushings, front end links, front sway bar bushings, front and rear coil spring isolator set, rear trailing arm bushing set, steering rack bushings, transmission shifter stabilizer bushings (manual transmission only), front ball joint boots and front tie rod boots.
The kit is for a 99-00 civic, now my question is will it fit a 92-95 civic. I looked on the website but it doesnt say if they are interchangable.
They say when a shark attacks you're supposed to punch him in the face. Then what, poke him in the eye with your nub.
Old Dec 18, 2008 | 08:06 AM
freakasis's Avatar
front control arm bushings lower only upper is differant
front shock bushings yes
front end links yes
front sway bar bushings no
front and rear coil spring isolator set yes fron rear maybe
rear trailing arm bushing set yes
steering rack bushings dont see why not
transmission shifter stabilizer bushings (manual transmission only) yes
front ball joint boots and front tie rod boots. yes
not 100% on this. feel free to correct me someone.
"Black people can't be racist" - Some black guy.
Old Dec 18, 2008 | 09:27 AM
The Big Diehl
thank you sir
