A Guide to Vtec
Old Nov 24, 2008 | 05:32 PM
Pete Stop Motor Co.'s Avatar
Default A Guide to Vtec
In the regular four-stroke automobile engine, the intake and exhaust valves are actuated by lobes on a camshaft. The shape of the lobes determines the timing, lift and duration of each valve. Timing refers to an angle measurement of when a valve is opened or closed with respect to the piston position (TDC or BDC). Lift refers to the distance the valve lifts off the valve seat. Duration refers to how many degrees of crankshaft revolution the valve is kept open. Due to the behavior of the working fluid (air and fuel mixture) before and after combustion, which have physical limitations on their flow, as well as their interaction with the ignition spark, the optimal valve timing, lift and duration settings under low RPM engine operations are very different from those under high RPM. Optimal low RPM valve timing, lift and duration settings would result in insufficient filling of the cylinder with fuel and air at high RPM, thus greatly limiting engine power output. Conversely, optimal high RPM valve timing, lift and duration settings would result in very rough low RPM operation and difficult idling. The ideal engine would have fully variable valve timing, lift and duration, in which the valves would always open at exactly the right point, lift high enough and stay open just the right amount of time for the engine speed in use.
VTEC was initially designed to increase the power output of an engine to 100 ps/liter or more while maintaining practicality for use in mass production vehicles. Some later variations of the system were designed solely to provide improvements in fuel efficiency, or increased power output as well as improved fuel efficiency.
In practice, a fully variable valve timing engine is difficult to design and implement.
The opposite approach to variable timing is to produce a camshaft which is better suited to high RPM operation. This approach means that the vehicle will run very poorly at low RPM (where most automobiles spend much of their time) and much better at high RPM. VTEC is the result of an effort to marry high RPM performance with low RPM stability.
Additionally, Japan has a tax on engine displacement, requiring Japanese auto manufacturers to make higher-performing engines with lower displacement. In cars such as the Toyota Supra and Nissan 300ZX, this was accomplished with a turbocharger. In the case of the Mazda RX-7 and RX-8, a rotary engine was used. VTEC serves as yet another method to derive very high specific output from lower displacement motors.
DOHC VTEC
Honda's VTEC system is a simple method of endowing the engine with multiple camshaft profiles optimized for low and high RPM operations. Instead of one cam lobe actuating each valve, there are two: one optimized for low-RPM stability & fuel efficiency; the other designed to maximize high-RPM power output. Switching between the two cam lobes is controlled by the ECU which takes account of engine oil pressure, engine temperature, vehicle speed, engine speed and throttle position. Using these inputs, the ECU is programmed to switch from the low lift to the high lift cam lobes when the conditions mean that engine output will be improved. At the switch point a solenoid is actuated which allows oil pressure from a spool valve to operate a locking pin which binds the high RPM cam follower to the low rpm ones. From this point on, the poppet valve opens and closes according to the high-lift profile, which opens the valve further and for a longer time. The switch-over point is variable, between a minimum and maximum point, and is determined by engine load; the switch back from high to low rpm cams is set to occur at a lower engine speed than the up-switch, to avoid surging if the engine is asked to operate continuously at or around the switch-over point. The DOHC (Dual Over Head Cam) VTEC system has high and low lift cam lobe profiles on both the intake and exhaust valve camshafts.
The VTEC system was originally introduced as a DOHC system in the 1989 Honda Integra and Civic CRX SiR models sold in Japan and Europe, which used a 160 bhp (119 kW) variant of the B16A engine. The US market saw the first VTEC system with the introduction of the 1990 Acura NSX, which used a DOHC VTEC V6 with 270 hp. DOHC VTEC engines soon appeared in other vehicles, such as the 1992 Acura Integra GS-R (B17A 1.7 liter engine). And later in the 1993 Honda Prelude VTEC (H22 2.2 liter engine) and Honda Del Sol VTEC (B16 1.6 liter engine).
Honda has also continued to develop other varieties and today offers several varieties of VTEC: iVTEC, iVTEC Hybrid and VTEC in the NSX and some Japanese domestic market cars.
SOHC VTEC
As popularity and marketing value of the VTEC system grew, Honda applied the system to SOHC (Single Over Head Cam) engines, which shares a common camshaft for both intake and exhaust valves. The trade-off was that Honda's SOHC engines only benefitted from the VTEC mechanism on the intake valves. This is because VTEC requires a third center rocker arm and cam lobe (for each intake and exhaust side), and in the SOHC engine, the spark plugs are situated between the two exhaust rocker arms, leaving no room for the VTEC rocker arm. Additionally, the center lobe on the camshaft can only be utilized by either the intake or the exhaust, limiting the VTEC feature to one side.
However, beginning with the J37A4 3.7L SOHC V6 engine introduced on all 2009 Acura TL SH-AWD models, SOHC VTEC was incorporated for use with intake and exhaust valves. The intake and exhaust rocker shafts contain primary and secondary intake and exhaust rocker arms, respectively. The primary rocker arm contains the VTEC switching piston, while the secondary rocker arm contains the return spring. The term "primary" does not refer to which rocker arm forces the valve down during low-RPM engine operation. Rather, it refers to the rocker arm which contains the VTEC switching piston and receives oil from the rocker shaft.
The primary exhaust rocker arm contacts a low-profile camshaft lobe during low-RPM engine operation. Once VTEC engagement occurs, the oil pressure flowing from the exhaust rocker shaft into the primary exhaust rocker arm forces the VTEC switching piston into the secondary exhaust rocker arm, thus locking both exhaust rocker arms together. The high-profile camshaft lobe which normally contacts the secondary exhaust rocker arm alone during low-RPM engine operation is able to move both exhaust rocker arms together which are locked as a unit.
The secondary intake rocker arm contacts a low-profile camshaft lobe during low-RPM engine operation. Once VTEC engagement occurs, the oil pressure flowing from the intake rocker shaft into the primary intake rocker arm forces the VTEC switching piston into the secondary exhaust rocker arm, thus locking both intake rocker arms together. The high-profile camshaft lobe which normally contacts the primary intake rocker alone during low-RPM engine operation is able to move both intake rocker arms together which are locked as a unit.
The problem which plagued previous SOHC VTEC systems from incorporating VTEC for both the intake and exhaust valves has been resolved on the J37A4 by a novel design of the intake rocker arm. Each exhaust valve on the J37A4 corresponds to one primary and one secondary exhaust rocker arm. Therefore, there are a total of twelve primary exhaust rocker arms and twelve secondary exhaust rocker arms.
However, each secondary intake rocker arm is shaped similar to a "Y" which allows it to contact two intake valves at once. One primary intake rocker arm corresponds to each secondary intake rocker arm. As a result of this design, there are only six primary intake rocker arms and six secondary intake rocker arms.
SOHC VTEC-E
Honda's next version of VTEC, VTEC-E, was used in a slightly different way; instead of optimising performance at high RPM, it was used to increase efficiency at low RPM. At low RPM, one of the two intake valves is only allowed to open a very small amount, increasing the fuel/air atomization in the cylinder and thus allowing a leaner mixture to be used. As the engine's speed increases, both valves are needed to supply sufficient mixture. A sliding pin, which is pressured by oil, as in the regular VTEC, is used to connect both valves together and allows the full opening of the second valve.
DOHC VTEC-DI
Honda also had a demonstration engine back in end 1999 where a 1.4 liter DOHC Honda engine was equipped with a VTEC-DI system. This was Honda’s first demonstration of direct injection to the public. The engine was installed in a Honda Logo (the predecessor to the Honda Fit/Jazz) and made power and torque outputs of 107 hp at 6200 rpm and 133 Nm at 5000 rpm.
3-Stage VTEC
Honda also introduced a 3-stage VTEC system in select markets, which combines the features of both SOHC VTEC and SOHC VTEC-E.
At low engine speeds, one intake valve is opened off an economy lift cam lobe, and the second valve is just cracked open a little to help promote better swirl in the combustion chamber. Used in conjunction with a 5-wire, wideband O2 sensor, great fuel ecomomy can be realized.
At medium engine speeds, both intake valves open off the economy cam lobe with equal lift allowing the engine to produce more power, but at the expense of economy.
At high engine speeds, both intake valves are actuated by a high lift cam lobe and produce much higher performance than at the medium speed range, but at an even greater expense of economy.
The 3-stage VTEC system was only offered in the Asian and European markets and not in the US market at all.
i-VTEC (intelligent-VTEC) introduced continuously variable camshaft phasing on the intake cam of DOHC VTEC engines. The technology first appeared on Honda's K-series four cylinder engine family in 2001 (2002 in the U.S.). Valve lift and duration are still limited to distinct low- and high-RPM profiles, but the intake camshaft is now capable of advancing between 25 and 50 degrees (depending upon engine configuration) during operation. Phase changes are implemented by a computer controlled, oil driven adjustable cam gear. Phasing is determined by a combination of engine load and rpm, ranging from fully retarded at idle to maximum advance at full throttle and low rpm. The effect is further optimization of torque output, especially at low and midrange RPM.
The K-Series motors have two different types of i-VTEC systems implemented. The first is for the performance motors like in the RSX Type S or the TSX and the other is for economy motors found in the CR-V or Accord. The performance i-VTEC system is basically the same as the DOHC VTEC system of the B16A's, both intake and exhaust have 3 cam lobes per cylinder. However the valvetrain has the added benefit of roller rockers and continuously variable intake cam timing. The economy i-VTEC is more like the SOHC VTEC-E in that the intake cam has only two lobes, one very small and one larger, as well as no VTEC on the exhaust cam. The two types of motor are easily distinguishable by the factory rated power output: the performance motors make around 200 hp or more in stock form and the economy motors do not make much more than 160 hp from the factory.
In 2004, Honda introduced an i-VTEC V6 (an update of the J-series), but in this case, i-VTEC had nothing to do with cam phasing. Instead, i-VTEC referred to Honda's cylinder deactivation technology which closes the valves on one bank of (3) cylinders during light load and low speed (below 80 kph) operation. The technology was originally introduced to the US on the Honda Odyssey minivan, and can now be found on the Honda Accord Hybrid, the 2006 Honda Pilot, and the 2008 Honda Accord.
An additional version of i-VTEC was introduced on the 2006 Honda Civic's R-series four cylinder SOHC engines. This implementation uses the so-called "economy cams" on one of the two intake valves of each cylinder. The "economy cams" are designed to delay the closure of the intake valve they act upon, and are activated at low rpms and under light loads. When the "economy cams" are activated, one of the two intake valves in each cylinder closes well after the piston has started moving upwards in the compression stroke. That way, a part of the mixture that has entered the combustion chamber is forced out again, into the intake manifold. That way, the engine "emulates" a lower displacement than its actual one (its operation is also similar to an Atkinson cycle engine, with uneven compression and combustion strokes), which reduces fuel consumption and increases its efficiency. During the operation with the "economy cams", the (by-wire) throttle butterfly is kept fully open, in order to reduce pumping losses. According to Honda, this measure alone can reduce pumping losses by 16%. In higher rpms and under heavier loads, the engine switches back into its "normal cams", and it operates like a regular 4 stroke Otto cycle engine. This implementation of i-VTEC was initially introduced in the R18A1 engine found under the bonnet of the 8th generation Civic, with a displacement of 1.8 L and an output of 140PS. Recently, another variant was released, the 2.0 L R20A2 with an output of 150PS, which powers the EUDM version of the all-new CRV
With the continued introduction of vastly different i-VTEC systems, one may assume that the term is now a catch-all for creative valve control technologies from Honda.
i-VTEC I
Honda’s i-VTEC I Engine is a variant of the K-series DOHC engine family featuring gasoline direct injection. It made its debut in the previous generation 2004 Honda Stream 7-seater MPV in Japan, but the current Stream does not use this engine anymore, instead using a 2.0 liter version of the R-series i-VTEC SOHC engine.
Old Nov 24, 2008 | 07:57 PM
kaluwa's Avatar
That's alot of words..
Originally Posted by steezyteg
ok guy your the idiot.
Old Nov 24, 2008 | 09:24 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Thank you captain obvious.
-Winston Churchill
Old Nov 25, 2008 | 05:01 AM
omgwtfbbq!'s Avatar
I race sailboats
^ +1
Should have posted this in Ford Tech
But seriously, the noobs who ask about vtech are not going to read this whole thing.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Nov 25, 2008 | 08:14 AM
sleepinsol's Avatar
starting over
cute..... how long did it take you to copy n paste that?
Old Nov 25, 2008 | 04:21 PM
About 1 min! LOL thought it would be good for the honda noobs!
Old Nov 25, 2008 | 05:00 PM
sleepinsol's Avatar
starting over
plaigerism!!!!!!!!! lock em up! lol at least cite your source dude.
Old Nov 25, 2008 | 05:19 PM
Juiced Dc2's Avatar
TR Events Admin
newb
We are what we repeatedly do. Excellence, therefore,
is not an act but a habit.
-Aristotle
Old Nov 26, 2008 | 05:06 AM
FC_V8's Avatar
Originally Posted by Juiced Dc2
newb
?? carter a noob? im pretty sure he knows more shit than you do...
and carter i got to talk to you about some welding...
