can a f20c head fit on a f20b?
Old Nov 14, 2008 | 09:04 PM
Chronik Fab's Avatar
Default can a f20c head fit on a f20b?
i have a jdm f20b and was wondering if i could use a f20c head.
Old Nov 15, 2008 | 03:43 PM
Anybody?
Old Nov 15, 2008 | 05:03 PM
Paulino's Avatar
Not harsh, just truthful
Read up.
Honda-Tech.com: Honda Prelude: The official H/F piston/rod/crank/block specs and CR thread
Old Nov 15, 2008 | 08:50 PM
Thanks Good Info, But I See No F20c Specs.
Old Nov 16, 2008 | 05:29 AM
Paulino's Avatar
What specs are you looking for? The F20B block and F20C head can't be put together.The F20C-These engines are unrelated to the F series engines found in the mid 90s Honda Accord and Prelude. They share many properties with the K series. These engines, unlike most F-series engines, has two counter-rotating overhead cams, a VTEC system for both the intake and exhaust camshaft, carbon-fiber reinforced cylinder liners (FRM),Molybdenum Disulfide-coated piston skirts for reduced friction, and uses a more modern chain driven valvetrain as opposed to a belt driven system.The F20C's bore is 87 mm (3.4 in) and stroke is 84 mm (3.3 in).The F20B in essence is basically a destoked H22A with a Bore of 85 mm and a stroke of 88 mm.
