Professional Products T/B
Old Nov 6, 2008 | 07:58 PM
civicSi07's Avatar
Default Professional Products T/B
Anyone running one having issues with the throttle sticking open when you let off the throttle? What can be done to fix this? Cause i can push the throttle lever closed and idle will go back down. I just installed this and have to get tuned in the morning! thanks!
1992 Honda Civic Si: SOLD
2003 VW Gti 1.8t: SOLD
Most recent: 88' B16 Turbo CRX: Totaled
PM me if you know me!
Old Nov 6, 2008 | 08:14 PM
custom240sx's Avatar
DC Crew Member #1
I would have tested it while it was off the car to see if it would stick or not...but I would have taken some very fine grit sandpaper (like 2000) and just gently smooth off the edges of the butterfly.
Old Nov 8, 2008 | 12:11 PM
CBURKE's Avatar
Has to many projects
I had one and if I can remeber it suck a little bit, but never stayed open or anything.
Cburke.industries.
Custom suspension bars, metal fabrication.
Old Nov 8, 2008 | 09:39 PM
civicSi07's Avatar
i ended up putting the stock one back on for now. ill have to sand the rough parts of the butterfly and see if it helps.
Old Nov 11, 2008 | 12:09 AM
SPOONCIVIC's Avatar
FUCKIN LOOONG BEDD!!!
alot of after market T/B are known to do this.some of the early skunk2 ones did im not sure about the newer ones tho.
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
Old Nov 11, 2008 | 03:30 AM
civicSi07's Avatar
i heard a lot of good things about the Professional Products t/b's. when im ready to put it back on, i may have had the throttle cable too tight, or ill just switch the spring and rotor from the stock t/b over to the new one. ill figure it out.
