Engine building ?'s again!
Old Nov 4, 2008 | 09:33 AM
J-PEZ's Avatar
Professional Hussla
Default Engine building ?'s again!
Where do I send my crank to get micro polished and how much?
Where should I send my block to get bored 1mm over to match my pistons?
What company or brand bearing kit should I get and where at, price range?
Where should I get 85mm head gasket (cometic prefered)
Where and how much should it cost to get my pistons teflon coated?
Where can I get arp head studs, main studs, flywheel bolts, etc. price?
Thanks for the help and another question how many lbs. flywheel should I use on a built boosted LS-Vtec? I know I shouldn't use the lightest but what should be the best?
Cheap Honda Parts! TypeR, civic, AEM, eagle, and more. W/pics! Check it out
___________________________
Tranceologist Powder Coating
Old Nov 4, 2008 | 02:39 PM
Evil_GST's Avatar
Pure Evil
google is your friend.
But if I must do the work for you inlinefour.com is where I used to order most of my parts back in the Honda days. they should have most of what you are looking for.
as far as machine shops eisele's is what I have always used, never had a problem with them and their prices are good.
Old Nov 4, 2008 | 03:48 PM
Alpha's Avatar
Originally Posted by J-PEZ
Where do I send my crank to get micro polished and how much? If you want to ship it Benson, ERL, Golden Eagle, etc. If you want to keep it local Engine Lab of Tampa, NAPA, etc.
Where should I send my block to get bored 1mm over to match my pistons? I hope you have sleeves. Answer to this is also above
What company or brand bearing kit should I get and where at, price range?Up to your engine builder. If built right most work. I prefer OEM, Clevite or ACL
Where should I get 85mm head gasket (cometic prefered)Golden Eagle
Where and how much should it cost to get my pistons teflon coated?Swain Tech, Calico or T-Bone
Where can I get arp head studs, main studs, flywheel bolts, etc. price?Gear Head
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Nov 5, 2008 | 07:46 AM
J-PEZ's Avatar
Professional Hussla
thanks ALPHA! ALso as for sleeves, all stock, lol, it's a test run just to see how long it last, I have another back up block just incase. I just want to see how long it will last on stock sleeves bored 85mm!
Old Nov 5, 2008 | 07:50 AM
Alpha's Avatar
The sleeves may last. The head gasket probably wont
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Nov 5, 2008 | 10:09 AM
J-PEZ's Avatar
Professional Hussla
lol, thanks bro, you're #1 (ALPHA)
