dumb question clutch
Old Oct 26, 2008 | 09:26 PM
91EF-9's Avatar
is tired
Default dumb question clutch
when i push the clutch theres no pressure until its almost to the floor what do i need to check/change i just bought the car so i havent really checked it out just figured i would ask sorry for lack of info will update later today thanks in advance
bucs2superbowl03@yahoo.com
Old Oct 27, 2008 | 06:36 AM
hondachris1994's Avatar
hatchback1994
1. clutch needs to b bleeded
2. check for leaks at the clutch mater inside the bay area and underneith the dash
3. check slave cylinder for leaks
if #2 or 3 is leaking replace then re-bleed and u should b good, but basically those are your options
Old Oct 27, 2008 | 06:57 AM
ResurrectedLS's Avatar
On the block
nah nah first check if you got hydro or cable tranny,..it can be that your cable is loose or your clutch is low..if hydro you got to bleed it like he said,...and then get back at us.
This is what 18 holes smells like!
RIP Pablo 3rd Garcia will be miss By Millions 9/28/85-9/4/2007
TR "Old Skool EF" Member #147
Old Oct 27, 2008 | 07:08 AM
91EF-9's Avatar
is tired
hydro thanks will let you know
Old Oct 27, 2008 | 08:13 AM
Jay's Avatar
Jay
Janky
getting a bleeder kit will make this much easier
Aim: o JankyJ o
http://jankycrew.com
