Ls Swap Into Eg ??????
Old Oct 15, 2008 | 10:15 AM
EG*5*CIVIC's Avatar
Default Ls Swap Into Eg ??????
I Want To Know If 94+ Ls Swap Comes With Obdii Or Obdi
And What Ecu To Use For The Swap Into A Eg Hatchy
Old Oct 15, 2008 | 10:29 AM
BABILLARACING's Avatar
93 to 95 obd1
Old Oct 15, 2008 | 12:24 PM
CBowesracing's Avatar
Stock Built Beast
P75 is the obd1 ecu, it will plug right into your harness under the dash where the other ecu was. and the 94 ls swap will go right in, you will need the bseries motor mounts and shift linkage.
www.myspace.com/chrisbowes
Old Oct 15, 2008 | 02:42 PM
stockcx's Avatar
Don't 4 get 94 + axles!!!! u should be good to go!!! It is lots of fun as a dd!
Old Oct 15, 2008 | 06:03 PM
freakasis's Avatar
motor mounts: 94-01 integra
axles: 90-01 Integra (as long as the intermediate axle is the same year as the drivers side axle)
motor itself: 90-01 integra LS
ecu: 92-95 integra LS
harness: 92-95 civic with mods or 94-95 integra LS will plug right in (92-93 might, not sure)
shift linkage: 94-01 integra
dizzy: 92-95 integra LS or rewire 96-01 (same internals, differant plug)
intake manifold: either 94-95 or 96-01 integra LS and change a few things (injectors mainly)
Did I miss anything?
Old Oct 16, 2008 | 07:45 PM
ekcoupe's Avatar
IS FASTER THAN YOU
i have a b series hasport tranny mount if u need it pm me i'll give it to ya for 30$ lmk
