****Forced Induction FAQ*******
Old Oct 2, 2008 | 07:44 PM
hondaking625's Avatar
DB1 FTW!!
Default ****Forced Induction FAQ*******
Welcome to the Forced Induction FAQ. If you are reading this congratulations you are educating yourself and helping Tampa Racing's tech section to hopefully grow into a vast area of tech info.
  • The purpose of this FAQ is to encourage other members to ask more in depth questions rather the troublesome, vague general ones we have all seen here before.
  • If you are new to the FI(forced induction) world, hopefully this faq will be able to give you a better understanding of the concepts of FI components and how they work. This is going to be a community FAQ. I will start off with a few, and encourage everyone to take a little time and post links to information they feel would be valuable in here.
  • If you are sick of seeing people posting "how much will i make/what times will i run" etc. Find the answer or write something up and PM a link or writeup it to me, or just post it here. I witht he help of the mods will check this post periodically and arrange your posts for quick reference.
  • hopefully we can make this as extensive and organized as the honda-tech FAQ.so start diggin out your saved info and post it up.
__________________________________________________ ________________________
READ BEFORE ASKING QUESTIONS
TURBO TECH 101 BASICS :
TurboByGarrett.com - Turbo Tech101
TURBO TECH 102 ADVANCED :
TurboByGarrett.com - Turbo Tech102
Turbo Tech 103 :
TurboByGarrett.com - Turbo Tech103
One of the best turbo reads :
G2IC Turbo Guide - A Guide to Turbocharging your Honda / Acura Integra
Heres how much boost (PSI) to run |explained :
Turbo D16 • View topic - FAQ: Here's how much boost (psi) to run
Horsepower: Supporting Parts needed to acheive HP goal Reliably| good for use as a guide for B/K motors :horsepower to part charts
Building on a Budget :
what I need to boost my ls? - B20Vtec.Com...... B Series and Beyond
How much can I make on a Stock Motor/How much HP will stock sleeves Hold :
Honda-Tech.com: Forced Induction: H-T's highest HP on a stock block thread....
Ebay turbo/turbo kit information :
Honda-Tech.com: Forced Induction: Noobs and EBAY turbo's, your question's answered.
Turbocharger flow map calculator | Various other Java Calculators FI related :
Ray Hall Turbocharging - Java turbocharger flow map calculator
Ray Hall Turbocharging - Java calculation applets
Turbine housing, Exhaust sizing, and Back Pressure :
Turbine housings, exhaust sizing, and backpressure.
Understanding your Turbo Size, A/R, and trim | Which one is best for you? :
Understanding Your turbo Size, AR and Trim - B20Vtec.Com...... B Series and Beyond
Engine Management Comparisons :
engine management comparison
Boost Controller Comparisons :
boost controller comparison
Air-to-Air Intercooler Information :
How to choose an air/air Intercooler.
How to size fuel Injectors :
How to size fuel injectors.
Fuel Injector information & Specifications specs
How to Clock a Turbo :
How to
When to upgrade fuel lines :
When to upgrade fuel lines.
How to choose a Fuel Pump :
How to choose a fuel pump.
Wastegate sizing :
Wastegate sizing.
Information on Crank Pullies :
Questions for the Experienced......... - B20Vtec.Com...... B Series and Beyond
_more PAGE 2....
pulley kits???????? - Page 2 - B20Vtec.Com...... B Series and Beyond
Differences Between Log, Cast, And tubular Exhaust Manifolds-Explained :
See References on First Page below..
Stock B20+Boost Debate/Information:
Stock B20 + Boost - B20Vtec.Com...... B Series and Beyond
Piston RING gap(install), Oversized valves and boost:
piston ring gap - Team Integra
Piston ring rotation:
Piston Ring Rotation
enjoyy guyssss
Old Oct 3, 2008 | 04:14 PM
SiR-Drew's Avatar
bump for a great reference
Old Oct 3, 2008 | 04:59 PM
Bite_Size's Avatar
עִמָּנוּ אֵל
i vote for this to be a sticky
great info and broken down to the point that my 7 month old daughter can understand
Old Oct 3, 2008 | 07:23 PM
DB1 FTW!!
sticky pleaseee
Old Oct 4, 2008 | 01:18 PM
Lookin2GoFA$T's Avatar
Team 'Petersburg Puller
Can you please cite this article?
www.floridasportsman.com
Originally Posted by P057
"Wow I had a hard time understanding that... but from what I gather you found an open-box item that wasn't cheaper. You bought it anyways. You then called someone a dumbass while making fun of their misfortune of losing a job as you were leaving the store?
I'm surprised you were able to get out the store with that big "SUCKER" sign affixed to your back.
Old Oct 5, 2008 | 04:35 PM
Bori300's Avatar
Bori300
quick question: is it correct where it says that the 90-93 ls's have 9.1/9.2 comppresion ratio???
TR 5th Gen Civic CREW Member # 17
TR "Old Skool DA" Member #55
Old Oct 8, 2008 | 07:12 AM
Bori300's Avatar
Bori300
i have a turbo question so might as well ask it in here... Im curently working on my turbo build and my question is as soon as i finish should i go get it tuned??? or break it in??? i dunno wat i am supposed 2 do.... cuz if i go get it tuned and it hasnt been broken in i risk braking something right???
Old Oct 10, 2008 | 03:26 PM
Bori300's Avatar
Bori300
no one??
